Question about Cell Phones
I have a samsung impression and i cant not get my headset to connect to because it requires a code for pairing is there anyway to get around it?
  • 314 Answers
The code you must enter to pair your bluetooth to your phone is four zeros..Hope that helps
www.usedcellphoneshop.com
Posted on Jun 07, 2010
I have a samsung WEP650 bluetooth earpiece. How do i get it into pairing mode please?
Starting with your headset turned off, press and hold the call button for some seconds as if you were turning it on, but keep the button pressed until its indicator light is steadily lit. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a little while, you headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There could be an indication on your phone that a headset is connected too.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you out any further.
Regards, Carlos
Jun 29, 2011 | Samsung WEP650 Bluetooth Headset
Tip
Turn on your bluetooth on your phone and paired with your Samsung WEp200
1. go to your phone click on settings, connection/connectivity, then bluetooth.
2. turn-on your samsung wep200, your cellphone will automatically search/find for available connection.
3. choose your samsung bluetooth wep200.
4. if prompt you want to pair with it, click on yes or confirm.
5. then enter the headset passkey/code/pin: 0000
6. then your all set.
this is the website i used to pair and unlock my wep200 to my samsung impression.its quick and easy.
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
on Feb 04, 2010 | Cell Phones
I have problem pairing the device with my LG VX8300. It is turned on and flashing but cannot be found in the search. I have also entered the 0000 code
Try to put your headset in pairing mode, prior to trying to pair it with your phone. If it has never been paired with another device defore, just by turning it on, it should enter that mode, denoted by its indicator light being steadily lit in blue. Otherwise, turn your headset off. Then, press and hold the Muiti-Function Button for far more seconds than the time required to turn it on, until its indicator light is steadily lit in blue. Then, within the next couple of minutes, bring your phone and headset close to each other, and make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make your phone connect to it. If a pairing code (or PIN, or passcode) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There should be an indication on your phone too, that the pairing process has been successful. Otherwise, turn you headset off and repeat the pairing process all over again.
Hope you are able to sort your problems out soon. Anyway, please, let me know if I can help you any further.
By the way, if your headset's quick start guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Jun 13, 2011 | Samsung WEP460 Bluetooth Headset
I cannot find my passcode for my Samsung Bluetooth WEP 460...can you help?
It is hardcoded to '0000' (four zeros). Anyway, put your headset in pairing mode, prior to trying to pair it with your phone. If it has never been paired with another device before, just by turning it on, it should enter that mode, denoted by its indicator light being steadily lit in blue. Otherwise, turn your headset off. Then, press and hold the Muiti-Function Button for far more seconds than the time required to turn it on, until its indicator light is steadily lit in blue. Then, within the next couple of minutes, bring your phone and headset close to each other, and make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make your phone connect to it. If a pairing code (or PIN, or passcode) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There should be an indication on your phone too, that the pairing process has been successful. Otherwise, turn you headset off and repeat the pairing process all over again.
Regards, Carlos
Jun 11, 2011 | Samsung WEP460 Bluetooth Headset
I can not connect my wep650 samsung blue tooth to my samsung epic4..
Regards,
Carlos
May 19, 2011 | Samsung WEP650 Bluetooth Headset
My htc phone cant find my samsung wep460 bluetooth
Regards, Carlos
Mar 13, 2011 | Samsung WEP460 Bluetooth Headset
Hello my name is Jaime now got a samsung Impression. My plantronics Explorer 220 bluetooth does not connect. Is it not compatible? thanks
Hi Jaime. You can follow theser instructions to pair a headset with your impression. Make sure the headset is fully charged and powered off before you start.
1. Make sure that bluetooth is turned on
2. Tap Menu.
3. Tap Settings.
4 .Tap Connectivity.
5. Tap Bluetooth.
6. Press and hold the on button on the headset until the light blinks red and blue. This indicates that it is in pairing mode.
7. Tap the Search button.
8. Select the headset from the list.
9. Enter 0000 for the pass key.
10. Verify Connection Options is set to Automatic.
11. Tap OK.
12. The Headset will display as a blue, connected icon.
Hope this helps!
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How to connect SAMSUNG bluetooth headset SBH 650 to my Nokia e71
When the pairing process between the E71 and SBH650 starts, try immediately to hold down, or press every half a second, the central 'call' button on the SBH650 - to force the SBH650 to think it is pairing with a new device. It took me 5-10 min of playing about in a similar situation, but eventually the SBH650 cleared it's 'memory' and the '0000' pairing code worked with another telephone...
however, I have never managed to pair the SBH650 with OS 3.0 upgraded ipod touch 2nd gen.
May 13, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
I cant pair my bluetooth to my blackberry pearl flip phone but my
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 18, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Searching for the headset on the Blackberry
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
