Question about HP G60-230US Notebook
HP G60-230US lap top won't turn on
Worked fine durring last use. Turned unit off after last use.
When plugged in next time the unit will not start up.
Power cord OK, light blinking under power cord socket.
    Scholar:
  • 58 Answers
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
If the issue persists after the above steps, then this could be due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. If your notebook is covered under HP Standard Warranty, then I would request you to contact HP Support to get your notebook repaired under warranty.
I believe the information provided would be helpful to isolate the issue with your notebook.
Posted on Jun 07, 2010
  • 1 more comment
  • larry ulmenstine Dec 04, 2010
    ok i ran into this same problem and it worked great thanks techiesguru ... but i also had to unplug the internal battery as well. but anyways here is my issue the battery wont charge.. and it wont run without the battery and the charger in at the same time.. if i run it without the battery with just the charger all i get is the light blinks 3 times and the pc powers off.. is it the ac jack, charger, or battery, any ways i can find out.. pls help techiesguru my laptop is a hp g60-231wm
  • Ben Oettel
    Ben Oettel Jul 18, 2011
    The G60 line of laptops had a bios issue when going to sleep or leaving them in sleep mode once the battery runs out they will not turn back on. I also have a G60 there is a bios update from HP that eliminates this problem. If you remove the battery and cord, hold down the power button for 5 seconds it will allow you to turn it back on once the battery and or cord is attached. Here is a link for the bios update:
    http://h10025.www1.hp.com/ewfrf/wc/softw...
  • Ben Oettel
    Notice the link is for the specific laptop listed in the original post above please refer to hp.com or ask me directly for your specific update, thanks!
You need a new power cord just had the same problem with the exact type of laptop
Posted on Nov 20, 2010
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Hi my lap top is vostro 1520 and there is a proble with it that i can not stand by laptop because when request to sleep it shut down or some thing like this (hibernate i don't know).and then when i...
Hi
Go to Control Panel, Power Options,
Then adjust the options there:
  • closing screen behavior,
  • pressing the power button behavior
and, tell us the results.
Good Luck
May 15, 2011 | Dell Vostro 1520 Notebook
Hi i have a vostro 1520 dell laptop there is a problem that some strange 1.my laptop when just full battery is connected to it won't turn on but when i press 20 to 30 sec the turn on key and...
First 2 of your problems are due to the fact that your laptop enters hibernation (or hybrid sleep in windows 7) and windows cannot restore your last saved state. The 3rd problem indicates you have windows problems (bad/not updated drivers, filesystem corruption, application issues). I would suggest you to reinstall windows.
May 14, 2011 | Dell Vostro 1500 Notebook
Television won't turn on.
Hello
The same problem i am also facing bin last weak what i will suggest you that neverturn off ur TV by remote switch off directly from the scree from next time it will be helpful for you from next time...
Thanks & Regards
May 24, 2009 | Televison & Video
My wireles not detect by my lap top
Common problem with motherboard. Needs service.
Jan 16, 2009 | HP Compaq nr3610 Rugged (PN686AW) PC...
Monitor will not turn on
does the pilot light go on?if there are no lights on,check plug,if your on a power bar,maybe you turned it off by accident,if it's new and none of the previous works ,run back to the store and RETURN IT
Jan 13, 2009 | Computers & Internet
Wifi problem
Have you checked the manufacterers website for any updates concerning this? (e.g. new wifi drivers)
May 25, 2008 | HP Compaq Presario V2000 Notebook
HP G60-230US Notebook Logo
2,757 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
