Question about Intel Motherboard
Intel motherboard shut down problem
I have applied the thermal paste and also bypassed the ups.still the problem exists.is there a problem with the smps kindly help me out i am bugged
    President:
  • 2,351 Answers
Harjeet83, you do not need to keep creating new posts. Follow the instructions listed to get you're answers from posted question.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
This was your last question & my answer.
http://www.fixya.com/support/t504384-still_motherboard_green_light
Mike
Posted on Apr 11, 2008
Overheating causes pc shutdown
You are correct. The machine will shut down or Blue screen if it over heats. The over heating can be caused by the Heatsink on the CPU or GPU not providing a good enough heat conducting channel for cooling. Cleaning the fan is a good start, but also be aware of where the PC stands, is there sufficient ventilation for example to extract the hot air?
Being an All -in-One will make more difficult. But check if all electrical connections are secure as the power supply can also cause your machine to shut down and the power supply fan should also be cleaned.
To apply Thermal paste you have to dismantle the machine and get to the Motherboard. I suggest you take it to a repair centre as the dismantling can be difficult in these units.
Feb 13, 2014 | Lenovo IdeaCentre B305-10052
Thermal trip
A MOTHERBOARD ARE SHUTTING DOWN THEN IT OVER HEATS.YOU SHOULD CHECK THE THERMAL PASTE,THE FANS.
AND LET NOT GET TO HOT IN THE CHASSI YOU MUST SE TO CIRCULATE THE AIR
Jul 10, 2013 | Intel Computers & Internet
Shut down
1) Computer dirty inside?
Air is used to cool the hardware components inside the computer.
If the Processor fan, and/or Heatsink is dirty, there is one of your problems.
The Thermal Paste on top of the Processor may have dried up too.
THOROUGHLY clean bottom of Heatsink, and top of Processor, then Properly apply new Thermal Paste.
2) What condition are the Radial Aluminum Electrolytic Capacitors, on the motherboard?
http://www.capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=oDGjWOabJ2E
http://www.hardwaresecrets.com/article/616
Post back in a Comment.
Regards,
joecoolvette
Dec 27, 2012 | Gateway HP 5188-8534 PAVILION A6110N...
My intel 945gtp board cpu overheating
A) I would use the Intel Pentium D, model D820.
It's a Dual Core processor with 2MegaByte of L2 cache, and an 800MegaHertz Front Side Bus. (800MHz FSB)
I would also use PC2-6400 ram memory, (DDR2 Sdram at 800MHz)
Using PC2-5300 (DDR2 Sdram at 667MHz) is taxing on the Processor.
If you are using an Intel Pentium D, model D506. It's maximum Front Side Bus is 533MHz. I would NOT use DDR2 Sdram at 667MHz.
Also is taxing on the Processor.
Why?
Primer:
The cache for a Processor is the FIRST memory area, the Processor accesses.
(L1, and L2 for the processors you named. Newer models have an L3 cache also)
It is a small memory area for the processor, and operates at the same frequency rate as the processor does.
(Frequency Rate = 'Speed')
The next memory area the Processor accesses is the Ram Memory.
Ram Memory typically operates at HALF of the FSB of the Processor.
With a D820 you are making the processor's FSB support Step Down, to use the 667MHz ram memory.
With the D506 you are making the processor's FSB support Step Up, to use the 667MHz ram memory.
http://www.intel.com/support/motherboards/desktop/d945gtp/sb/CS-026628.htm
More work for the Processor = More Heat
B) Next, how you applied the new Thermal Paste.
Notice I stated N-E-W.
This is because thermal paste can dry up, and also loose it's thermal conductivity properties.
Don't skimp in this area. Thermal paste is C-H-E-A-P!
C) What kind of thermal paste did you use?
Primer:
The thermal paste that has real silver in it, is an Excellent thermal paste, BUT needs to be applied properly.
Why?
Because silver is an excellent conductor of ELECTRICITY, as well as heat.
If too much is applied the excess will ooze off, once the Processor reaches operating temperature.
Means the thermal paste will ooze down off of the Processor, onto any solder joints it can reach, AND the contact pins of the Processor.
This can cause a Short Circuit. May just cause overheating until the wrong solder joints, or processor pins are reached, by the oozing thermal paste.
http://www.hardwaresecrets.com/article/274
Proper cleaning of the top of the Processor, and bottom of the Heatsink
The old thermal paste, or thermal pad, needs to be THOROUGHLY removed. Use a plastic scraper
(Old credit card, or one you got in the mail? "Now you too can have a XXXXXX credit card!" Bah, sheesh!)
Scrape off as much as you can. Then use Q-tips dipped in Isopropyl Alcohol. (Rubbing alcohol)
I use 91 percent, (91 percent alcohol, and 9 percent water)
You can use 70 percent, but I do NOT recommend 50 percent.
(50 percent alcohol, and 50 percent WATER)
CAUTION!!!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!!
Use in a WELL ventilated area with NO sparks or flames present!
Takes a LOT of alcohol dipped Q-tips. The top of the Processor, and bottom of the Heatsink, needs to be THOROUGHLY cleaned.
Clean enough you could literally eat off of it. (But DON'T)
D) When you put the Heatsink/Fan combo on the Processor, did you hold the motherboard in the air, and look across the motherboard with a 'birds eye view', at how the Heatsink is sitting on the Processor?
CANNOT be tilted. Has to have the entire Heatsink area, sitting flat on top of the Processor. If you can see ANY, daylight in-between the top of the Processor, and bottom of the Heatsink, START OVER.
E) What kind of Heatsink/Fan combo are you using? May be too small for the job, or not the correct one.
F) Does the computer tower have plenty of room around it? You are supposed to have at least 3 Inches of room, all around the computer case. In your instance I would use more.
G) Taking the side cover of the computer case off, to help cool the Processor. This = NO, unless you have an external fan blo-wing air into the open case.
By taking the cover off you are decreasing the cooling power, of the computer case fans.
The Intel Pentium D, model 820 can use up to 95 Watts of power.
At that maximum wattage usage, the maximum allowed temperature
is 64.1 degrees Celsius.
You are correct. Shouldn't be at 65 degrees Celsius just loafing. (Idle)
http://ark.intel.com/products/27512?wapkw=thermal+range+for+pentium+d+processor+820
Quick Links > Download Datasheet
PDF file page 78, Table 5-3
Regards,
joecoolvette
Jul 02, 2012 | Intel Computers & Internet
The computer shuts down after 10 to 30 min..I have already change the fan.
When computers shut down like this they are getting the signal from the motherboard. This is most likely a thermal shutdown signal from the processor. When you changed the fan, did you clean the processor off and apply a small thin layer of thermal paste? The processor may not be cooling properly or the motherboard is getting a bad signal from the processor's thermal circuit. Try new thermal paste on the processor and then go through the board again and make sure everything is in its place. Also, leave the side panel off and see if the system stays running, this will aid in the cooling. Let us know if it works, if not we may have more ideas to help.
Aug 25, 2010 | Computers & Internet
Sister, Son and I all have the same model Sony Desk Top Computer. Model VGC RB57GY. Computers are overheating and showing overheating error and shutting down. Mine now is shutting down after even a...
May I ask what Temperature you are referring to, and where you are looking for the temperature at/in?
In BIOS?
Do you have external software that reads these temps?
Motherboard temperature?
CPU (Processor) temperature?
ATI Radeon X300 graphics card GPU temperature?
(Graphics Processing Unit)
CPU temp:
What Processor is installed, and what is the maximum thermal limit for it?
Intel Pentium D Model 820.
http://ark.intel.com/Product.aspx?id=27512
64.1 degrees Centigrade, or 147.38 degrees Fahrenheit.
Checked the thermal paste to see if it has dried up?
Even if it hasn't, cleaning the bottom of the Heatsink, and the top of the Processor's case, and applying fresh, new, thermal paste is the way to go.
After a certain amount of time, thermal paste loses it's thermal conductive properties.
If it is a thermal pad, remove it, fly it out the window. They're junk.
Use fresh new thermal paste instead.
(Be sure to observe Anti-Static Precautions)
Fans are all working fine.
According to whom?
The tech?
Not doubting your abilities for one second. DO doubt the many 'techs' who profess so.
Computer case open, observe the Processor Fan. Ensure that is is spinning at all times, and not intermittently.
Also ensure that the fan is spinning at the correct RPM's.
(Revolutions Per Minute)
Same with the computer case fan's, Front and Rear.
Computer clean inside?
1) Processor fan?
2) Heatsink?
3) The area of the motherboard you can see with the computer case open?
4) The area Behind the motherboard, that you Cannot readily see, without removing the motherboard?
5) The ATI Radeon X300 graphics card?
6) The Heatsink on the Northbridge chipset?
Check the cable connection of the Processor fan to the motherboard, and the computer case fans, IF, they (Case fans), have three wires, AND are connected to the motherboard.
One wire is for Power
One wire is for Ground
One wire is for a sensor that detects when the fan should speed up.
Processor fan spin freely? Computer case fans? Feel like they/it, may have a bad bearing?
Let's diagnose together, and see if we can solve this.
If all of the above reads like a foreign language to you, I will explain step by step, and guide you.
Aug 16, 2010 | Sony VAIO VGC-RB57GY PC Desktop
When I boot the machine it gives me a thermal overheat event msg and shuts down, I believe the thermal contact between the fan and processor has broken, I do not know how to remove the cpu fan and re apply...
Theres many types of sockets for motherboards. If PC clone, search for the book manual for pinpoint wath socket it it or it is a IBM or DELL or HP, the same except the latter is little more tricky when detaching the heatsink. Once figured out, disconect the power, touch the fuselage of the PC to discharge from ESD. Of course, buy a heatsink compound and you can clean the cpu and bottonm of the heatsink with paper towel and Isopropyl Alcohol and apply new compound. Not too much, the nessesary only. I'd like to apply in a whirpool like on the CPU. And the heatcopound color grey is the best.
Aug 21, 2009 | Intel D845GLLY Motherboard
Overheating problem
have you controlled in windows task manager for programs that is overloading processor and ram? if not press ctr+alt+del go to processes and in the end of windows look fo processor loading, is given in%. do this when your computer is seem to go in shut down ,,a little before (ex after 2 hours).
if you find somethin there , aprocess that is overloading your cpu kill process imediatly presing end process button. if you didn't find something there , have you cleaned your old thermal paste from cpu before aplying a new one? have you inserted cpu cooler in his right place if yes , try to change your processor because is it damaged due of ecsess of heating per wat that it can. prove with another processor , if the problem persist then put acooler to the chipset that dont have a cooler if problem persist you must change a MB.
another question have you suficcient watage in your power supply to cover all your devices you have in your pc?
Apr 07, 2009 | Intel D915GAG Socket 775 Motherboard -...
Turn off with in 1 min.
That is most likely the proccessor overheating and shutting down.
Remove the processor's heatsink and fan, clean off all the old thermal paste with alchohol and a cotton swab, you can use a piece of plastic like an old credit card to remove any stubbon thermal paste.
Reapply the thermal paste (about the size of a grain of rice is sufficient) and reattach the heatsink and fan then start the machine up again.
Sep 12, 2008 | Intel D101GGC Motherboard
Problem with just yello light of the motherboard
Hello again harjeet83, (Did you put some thermal grease on your CPU)? Try bypassing the ups & plug directly into a wall socket.
Let me know if doing this has stopped the PC from shutting down?
Mike
Apr 05, 2008 | Intel Motherboard
Intel Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
