Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP30 , how to change convergence
I have had the convergence changed on my JVC 3 times and they are out again. Instead of paying 300 to have a shop replace them I was attempting to change them myself. I have never worked on a television before so i was looking for step by step instruction hopefully with some pictures as well.
  • JVC Master
  • 8,457 Answers
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries Amazon.com to buy solders.Tries wesites like Tvrepairworld.com to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Posted on Jun 07, 2010
    Problem Solver:
Put new ic chips in tv checked all fuses still color wont line up help
Posted on Mar 17, 2011
My jvc model # av-48wp30 tv has a blue shadow
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
Aug 08, 2010 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 blue to align convergence
Tv colors R,G,B don't alignment any colors.Tv have a convergence problems,it dead.Tv convergence board require changes 2 STK convergence ICS and some or all it resitors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 foggy image
Check convergence adjust screen after picture distorts.
Description sounds like shading from a defective convergence circuit. If you replaced STK392-110 with 150, then re-install new 110's, or new 150's and re-design the circuit and change low-ohm resistor values to compensate for different IC's. It is not the same as a brighter light bulb.
See if the picture is in the CONVERGENCE GALLERY
easyab
Oct 18, 2008 | JVC AV-48WP30 48" Rear Projection...
Av-48wp30
If the convergence Ics and resistors are good its most likely related to the velocity boards that are attached to the Red CRT convergence yoke. Its the small board about half way up the neck of the CRT. If you need one let me know as I have a source for JVC boards for that model.
Jun 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem
Its located in the front behind the speaker panel there s a nother small access panel the convergence board is right there on the right hand side up front.
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 convergence problem
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Mar 16, 2008 | JVC AV-48WP30 48" Rear Projection...
I have a jvc av-48wp30 rear projection widescreen
check your soldering and make sure all the pins are soldered and you don't have any solder bridges.
have you checked the resisters?
Jan 31, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48WP30 48 in. convergence
Imagine 2,4,6,8 like a joystick. Press 2 to move the spot to the left, 4 to the right, 8 down etc. To change the color press select. If is not moving you got hardware malfunction.
Dec 07, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
541 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
