Question about Magic Chef Kitchen Ranges
When I turn the front burner on. I get a clicking noise on the back panel under the control knobs. Other burners take an exceedingly long time to come to temp.
    President:
  • 1,561 Answers
Tighten all of your electrical connections. Inspect all of the low voltage wiring for any insulation cracks or other damage. The problem you describe sounds like something is either "shorting" or breaking down electrically. Unless the technician can catch it while he/she is there, it will be difficult to determine exactly what is happening. You might get lucky and resolve it yourself by tightening all electrical connections and reinsulating (use electrical tape) any damaged low voltage wire connections.
You can also follow the below link to see how you can troubleshoot your burners.
http://www.familyhandyman.com/DIY-Projects/Home-Repair/Appliance-Repair/how-to-repair-a-gas-range-or-an-electric-range/Step-By-Step#step5
Type the above link in your web browser to see the information therein.
Take care.
Posted on Jun 07, 2010
My right front burner wont turn off. My dad checked the control knob and it seems to be working. He unplugged it from the front burner and put it on the back to see if it did the same thing and it did. ...
with a model number to know exactly how power is supplied to the surface burners its going to be hard to let ya know anything definate...but do ya have knobs that ya turn to turn on the surface burners? if yes knobs..their will be terminals on the switch marked L1/L2 on those 240vac should be there all the time when turning the knob onto high on terminals marked H1&H2 should be 240vac to the burner
if it has the touch button to turn on the surface burners 240 vac into board all the time ..4 individual outbound power places (one for each burner) and the one for that burner also should have 240 vac when set to high
in either case if 240 vac out to burner the burner is bad
if 240vac into switch/board and not out..switch/board bad
Aug 26, 2011 | Kenmore 99123 Electric Kitchen Range
Firemagic ECHELON E660i - flames shoot out around the orfice heat stressing the front panel, making controll knobs too hot to touch and allowing flames to shoot up onto the lid, grill is 20 months old. ...
Has this been happening since new or did it just start?
Either way, you need to check the burners for proper placement over the burner orifices. Are they fitted snugly? Are they running perfectly parallel to each other and resting properly on the back inner cabinet of the grill, in the burner holders.. Also, make sure that the orifices are screwed in tight and are not clogged. Check the burners for clogs and if found clean out the burners, by gently tapping them on a firm surface.After doing that, turn the up so the orfiice end is down and see what falls out of the burner(s). If the burners or orifices were clogged or the orifices not tight, it may be backfiring into the control panel. This can also indicate a gas pressure problem.
If you can remove the front control panel (remove the burner knobs, first) you can access the gas fittings to each burner's control knob and it's gas fittings. Without lighting the grill, turn each burner ON and check for leaks with soapy water at all the connections. Then turn it off and check for leaks again.
If you found any leaks, check each fitting to make sure it's not cross threaded and re-tighten.
If none of the above solves the problem, contact the Fire Magic Dealer you purchased it from or the R H Peterson Company (they make the Firemagic Grills), as it may be a manufacturer's defect. They have an excellent warranty program. For a warranty claim, you will need your Proof of Purchase.
Hope this helps to get you back grillng>
Feb 21, 2011 | Fire Magic FireMagic Grill
When turning on the burner, the gas does not always flow
There is usually a switch under the knob thaat controls the electrical sparker. OFTEN these get messed up when the area around the knob is cleaned and water gets behind the knob.
Dec 05, 2009 | GE Cooktops
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Sep 26, 2009 | Kitchen Ranges
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Range burners
There must be a problem in one of the switches which is behind one of the knobs. Will have to check each switch with a meter.
Oct 03, 2007 | Tappan TGFS_63 Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
14 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
