I have a 95 ford f-150 and i just bought a Phase Linear and it said to hook up the pink wire to the parking brake so i found the parking brake wire and hooked it up and it keep saying that its illegal to watch this while driving, so what wire do i hook the pink wire up to..
    Novelist:
  • 100 Answers
The problem is that it wants you to be legal so it will only work when the parking brake is set. A way around this is to either ground it directly. Or you could put it on a switch to ground so if you get pulled over you can flip it quick and not get caught. It's up to you. I hope I could help.
-Andrew Hawkins
Posted on Apr 10, 2008
I have a phase linear uv8035 deck and it won't let me see video.
if the wire(should be pink in color) is hooked to the brake circuit then there is a procedure you must use to watch videos. If the brake is already on when you try to view video, release brake for about two seconds then reapply. If the brake isn't on when you start video apply brake for about two seconds release and then apply brake again.
Mar 18, 2009 | Car Audio & Video
Parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Jan 30, 2009 | Jensen VM9411 Car Video Player
Phase linear uv7i
install a switch with one end going to ground and the other to the pink barking brake wire off the deck switch it to on"ground" for 3 seconds then off"no ground" for three seconds do this 3 times and then leaving it in the ground position and it will work but the car must be in park when you do this
Jul 12, 2008 | Phase Linear UDV9010 Car DVD Player
Place the pink wire to a ground. Hope this works for you.
Jun 01, 2008 | Jensen VM9410 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Need to by pass
There are two ways of bypassing the brake sensor in a Phase Linear UV8:
1. ground the pink wire using a toggle switch;
2. Use the unit's built-in bypass software.
a. Select "Tuner" mode (AM/FM);
b. Press the "Setup" button;
c. With the use of the remote, press 5, 4, 3, 2, 1, and then press and hold 0 for a couple of seconds or until the menu changes. d. d. Display should show hidden menu. Among the options would be to turn ON the "Brake override";
e. Press th "X" on the bottom leftmost corner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Televison & Video
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
137 people viewed this question
 Grubhead
Grubhead
