Question about Samsung YP-U3 MP3 Player
The player refuses to play songs
When I go to play certain songs on my YP-U3, it freezes and displays the message "System Fail! power will be turned off". On other songs, it skips, especially at the end of the track. I was told by Samsung to send away for a product exchange, but the same problems appear on the new player! I have checked the song files, and they aren't corrupted, so...what is going on?
  • Anonymous Jul 26, 2008
    yeh same here, wen i switch it on it says the same thing, it just happened out of nowhere, dnt no wat 2 do
Panda
Posted on Apr 10, 2008
My samsung yp - u3 cannot conected in my computer
Posted on May 07, 2008
Samsung YP-U3 mp3 player display is DEAD..won't
Probably the display is off. Go to Settings and change 'Display Off' setting to 'Display On'. I have attached a link to a PCMag review of your player to help you.
Samsung YP U3
Dec 18, 2014 | Audio Players & Recorders
Just when I played a song, it suddenly stopped playing
I have the same player.The best thing about this player is that it is very repairable.
Just do the following...
1. Turn player on > Settings > System > Format. And then reload only few songs and check if it works or not.
If the above method doesn't work, then...
2. Connect it to a computer > Right click on the player > Format.
After formatting it must work. If it still doesn't work then obviously the problem is with the music files that you played.
But still... you may try installing the firmware... the following is site from where you can download it.
http://www.samsung.com/my/consumer/detail/support.do?group=mp3audiovideo&type=mp3player&subtype=mp3player&model_cd=YP-U3ZB/XME&mode=C
OR
http://www.samsung.com/sg/support/download/supportDown.do?group=mp3audiovideo&type=mp3player&subtype=archivedmp3&model_nm=YP-U3ZB&mType=&dType=D&vType=R&prd_ia_cd=03040600&disp_nm=YP-U3
Please Rate if you find the above info useful, and please comment if the problem is solved or not.
Aug 25, 2009 | Samsung YP-U3 MP3 Player
Can turn it on, comes up with Log Val 0x10000024
THIS FOR SURE HELP!!!!!!!Hi...I find the answer...Push and hold rec button and button for holding...And it will start..if your mp3 (a samsung yp-u3 mp3) says log val=0x10008018 or something, click and hold the record button and once it begins to record, press the back arrow/button (symbol in the top right corner). your mp3 should work (play music and such) now. to fix your mp3 and get rid of that log val message, you need to go to settings, then system, then format. format your mp3. unfortunately this will delete all your songs and files on the mp3, but the mp3 player should be fixed and the log val message wont appear anymore.
hope this helped....
May 29, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-u3 want repeat a song
if u didnt try the program button next to the play/power button, go into the settings on it and u can to it manually
May 08, 2009 | Samsung YP-U3 MP3 Player
My Samsung Yp-U3 Freezes Up
the reset button is in the back then it will say reset then use a pin or toothpic and it is that little hole
Feb 05, 2009 | Samsung YP-U3 MP3 Player
Wont power on completlley dark
Hold the on/off, record, and hold buttons all at the same time.
Mine actually did the same thing and it worked for me.
I found out that it was only doing it for a certain song, so you might also want to check the song you're listening to and delete it from your playlist.
Nov 24, 2008 | Samsung YP-U3 MP3 Player
Log Val in screen
Upgrade the firmware:
http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U3JQPY&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03040200&disp_nm=YP-U3JQPY
Then use Windows Media Player to transfer the songs.
May 30, 2008 | Samsung YP-U3 MP3 Player
System fail
I had the same problem with a YP-U3 and was able to fix it by installing upgrades from the Samsung website. First I downloaded an firmware upgrade from ver. 1.11 to ver. 1.13. The upgrade consists of two winzip files that need to be copied to the system folder on the YP-U3. After the two files were copied, the firmware upgraded itself when the MP3 player was turned on, but I still got a "system fail" message. Then I downloaded the latest version of Samsung Media Studio 5.2 from Samsung.com. The Media Studio menu has a function for reformatting the MP3 player, which clears all data files but leaves the operating system intact. After that was done, the MP3 player worked properly.
Apr 14, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Logo
209 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
