Question about Panasonic Lumix DMC-TZ3 Digital Camera
All indoor pictures look grainy or blurry. There are a lot of noise in my photos, and it really seems to have difficulty capturing moving people as the intelligent auto often chooses the night portrait scene for indoor people shots. In the manual it recommends using a tripod and having the subject stand still. I am trying to photograph active toddlers (18 months and 3 years old). I have found switching to sports helps sometimes. The baby setting seems useless unless they are sleeping since it uses a weak flash to get a truer skin color. Perhaps the skin color is better, I can't tell since they are all just a blur of movement. I have gone through the instruction manual and menus to turn on all automatic settings I could find such as I exposure, I iso max 800 as recommended in several reviews, I resolution. There is not much you can set in the Iauto setting except turning off facial recognition. It seems to capture motion worse than my 5mp olympus 5060W did. I have now increased the noise reduction to +1 although I all the reviews indicate it tends to loose details due to noise reduction as it is. I find the opposite. Am I just inept or is there some setting I should try. This camera got so many great reviews, why can't I make it work well?
    Brigadier General:
  • 11,967 Answers
Stop using the IA mode. Just use normal picture taking mode with auto flash.
Posted on Jun 07, 2010
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
Blurry indoor photos
blurry pictures often comes from the slightest movement when the pictures is snapped.
Don;t know if that is your problem or not try a photo tripod and see if that helps or check your trouble shooting area of your amnual. if you don't have the manual go to this site for any type of manual::::
http://tv.manualsonline.com/search.html?q=vr+5940&submit.x=35&submit.y=14
Aug 28, 2009 | Cameras
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Indoor sports pictures
For sports photography, and especially indoors, you really need to be looking at a digital SLR camera. To freeze that sort of motion you need to be looking at a shutter speed of around 1/200 sec or less.
Most compacts won't do this as the light through the small lenses is a lot less than with an SLR. I've just looked at the sports mode on my wife's DMC-TZ5 and it doesn't even tell me anything about shutter speeds or aperture sizes, it's all automatically controlled by the camera.
The only way you would be able to make any difference with your camera is to increase the ISO setting to the highest possbile setting (1600 on the TZ5). The will reduce the blurring somewhat, but will also introduce some noise and graininess into your photos.
See how you get on, if not good enough I strongly recommend you hire a digital SLR for weekend and see the difference it would make - but you would also need a decent lens and this is where SLRs get very expensive!
Good luck
John
Jan 19, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Not good photos indoors very grainy and bad light looking photos
Auto mode in poor lighting (generally always indoors without flash) sets high ISO, which produces ugly amount of noise (graininess). What you need is to keep the ISO under 200 by either:
Shooting well lit scenes, using flash etc.
or
Uusing one of the manual programs (M, S, A, P) and setting the sensitivity via the F-menu.
Dec 27, 2008 | Fuji FinePix S8000fd Digital Camera
Horrible indoor pictures
can i have a look at the picture please
Oct 16, 2008 | Kodak Easyshare M753 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Pictures out of focus indoors
Maybe your camera has a problem with flash unit. Replacing the flash unit can solve the problem. Part number of the flash unit is: A7113088A. If you need more help, please advice. Arpi
Mar 17, 2007 | Sony Cyber-Shot DSC-P93 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
409 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
