Question about Yamaha HTR-5860 Receiver
We have to hold the remote control button hard and straight at the reciever for ti to work
  • 4 Answers
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Posted on Jun 08, 2010
I have a Sony theater reciever that I bought off eBay with no remote. So I looked around and Sears was selling a Sony Universal remote RM-VZ220 saying it was compatible with my Sony STR-K670P AM/FM...
1. Make sure you have good batteries in the remote and they are installed properly.
2. Press the DVD button on the second row of the remote, then check if the Power and other buttons on the remote work with your system (it probably won't since the factory setting is for a Sony DVD player, not a home theater system).
3. If it doesn't work you need to find the correct code number for your system and enter it into the remote. Press and hold the SET button for more than 3 seconds until the SET indicator lights up. Keep holding the SET button down and press the DVD button, then release both buttons. Then enter the code 31622. If you have done this correctly the SET indicator flashes 3 times, if not start over.
4. See if the remote now controls the theater system correctly. If not, repeat the above procedure #3 with the following codes one at a time until you find one that works: 31558, 31658, 31758, 31822, 31858, 32522.
May 23, 2014 | Audio Players & Recorders
Bose 321 series ii remote control
try remote on your tv...hold tv button till it lights up and enter code for tv till red led goes out...then try it on tv..if it works,then your ir reciever is kerput...not your remote.i am trying to find parts for mine as well.
Oct 01, 2012 | Bose (321GS) System
Can't use remote to change dish channels batteries are working fine
Hello my name is Michael Hurst with DISH Network. Sounds like your remote may need to be reprogrammed to the DISH receiver. You can press the Menu button on the receiver and that will get you to the System Info screen. Once you have this screen then press and hold Sat button until all the buttons on top of the remote flash red. Let go of the Sat button and pick a number between 1-15. Once the number is selected then press # and then Record. Watch the remote code number on the System Info screen. If this doesn't work then unplug the reciever from power outlet for 10 seconds and perform the step again.
Jul 03, 2010 | DISH Network IR Remote Control
Can I adjust the level of each channel from the receiver, not from the remote control (the level button on mine is not working)?
Depends on the reciever, some due and don't, my advice is to get a universal remote that will work with your reciever and then you can adjust your settings no problem. I own a Yamaha RX-V3800n and you can hardly do anything without the remote.
Hope this helps
Sep 24, 2009 | Panasonic SA-HE7 Receiver
Opener will not recieve programing instructions from the keypad.
There should be a button on the back of the door opener that says "teach" or "learn". Push that button, a light comes on and you have about 30 seconds to program the control by holding it near the unit and holding the remote button down. The opener will then learn the code from the remote.
Sep 17, 2009 | liftmaster Chamberlain Garage Door Opener...
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
I have the same problem
try to drop the 3 when programming that remote
Jun 12, 2009 | Yamaha HTR-6130 Receiver
3.1 DishnetWork remote problem
I suspect that the remote address got changed somehow. Pree and hold the sat button on the top left hand side of the remote until all buttons light up across the top and release. Now key in 0-1 on the numeric keypad and press the pound sign. The SAT button will flash three times. After it the SAT button is done flashing press the small red dot record button. Now try to operate the remote. You should be able to control the system now. Thanks for using Fix Ya.
Mar 13, 2009 | DISH Network IR Remote Control
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Open Questions:
See all Yamaha HTR-5860 Receiver Questions
Yamaha HTR-5860 Receiver Logo
175 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
