Question about Refrigerators
Caple WCi46B Wine Cooler Fault code of E4. What is this fault?
2 Suggested Answers
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
E4 code on display
E3 & E4 error code means problem with the connectors for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust.
Check the fan connectors by removing the two screws that hold the shelf in place and cafefully slide out fron the cooler. Just replaced the factory connectors with insulated bullet connectors.
Hope this helps; and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment.
Have a nice day and thanks for using FixYa.
Jose.
Oct 17, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a e4 code on my wine cooler
I am sorry to hear regarding the trouble. This is a common problem on this unit. E4 refers to a faulty control board failure. Unplug the unit for few minutes, say 15 minutes and then turn it on. If this would not reset the error code, the only solution is to replace the board.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Danby DWC283BLS Wine Cooler
Code E4 on dandy wine cooler mod # dwc283bls
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Feb 18, 2011 | Danby DWC283BLS Wine Cooler
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
E4 message
Disconnect the power cord from the wall outlet and wait 30 minutes before pluging back in. This should clear all settings on the cooler.
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS.pdf
Aug 07, 2009 | Danby DWC283BLS Wine Cooler
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
E4 Code
Nov 17, 2008 | Refrigerators
E4 Code
Dear moriquenda
welcome to fixya.
Did you try resetting the system by pulling the plug and waiting 5 minutes then restarting the wine cooler?This may solve you problem.
Danby expects customers to call service and does not imagine the rest of the world being able to utilize these codes.
Closed minded, Huh?
Please remember to leave a rating!
Huuum
Sep 28, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Jul 13, 2008 | Danby DWC513BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
