Question about Husqvarna Partner Gas Powered Cut Off Saw K960 16"
How do you remove a carb off a K750 partner saw??
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: Renew pull start cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Posted on Nov 25, 2009
Testimonial: "Thank you for your advice - excellent!"
Husqvarna K750
sounds like a plugged intake port. remove carburator and cycle cylindar to lowest point, pathway to cylindar interior should be open
Jun 18, 2014 | Saws
Engine stuck wide open , full throttle
It is possible your linkage arm fell off or there's junk blocking that arm from releasing - you'll need to remove the top cover and inspect the linkage arm for blockage or a missing cotter or compression pin. Remove said cover and look for the trigger linkage arm off the trigger assembly. follow to the carb, watching for blockage or missing pin(s). The natural vacuum of the carb should pull the accelerator to idle, unless the configuration ( linkage) is bent or blocked. With some saws, you may need to remove more then just the top cover, and some require the removal of the safety brake bar, which can be difficult as they usually have a hidden spring that like to fly away, taking other crucial small parts with it ( I have a saw that is now brakeless because of that mean little spring!). Depending on your level of mechanical aptitude, you may want to consider taking it to a reputable shop.
Hope this helps!!
Dec 01, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Repair manual partner k750
http://speedy.sh/A7tjW/K750.pdf This should give you the shop manual
Feb 08, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Partner k650 wont start when warm
This is a pretty common carb issue, the needle in the carb is leaking, if dirt has been throgh it then the needle seat will be worn, the only answer to this is a new carb unfortunatly.
Jul 08, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Oil ratio partner k750
40ml to 1 litre of fuel 150ml to to 1 gallon
May 19, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Partner K750 wont start
i have seen these saws split the diaphram in the carb, so get that carb out and take off the bottom 4 screws... also iv seen 1 with the igniter coil gone weak and only sparking the plug the odd time so make sure yu hav a good spark also...
Jun 06, 2009 | Husqvarna Saws
Husqvarna Partner Gas Powered Cut Off Saw K960 16" Logo
433 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
sgtstrat
Level 1 Expert
ken skalski
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
