Question about Car Audio & Video
Why do i get power to my amp but no sound - Car Audio & Video
  • 94 Answers
Are the RCA cables hooked up correctly?
Posted on Jun 07, 2010
I have a Marantz Digital Integrated Amplifier PM75 and experiencing with LP's and CD's that I get a loud popping sound , thereafter no sound until after several minutes when it comes back on.
If the sound is common to both channels plus on different functions, it is either a part that is common to both channels or is in the power supply. It will be either in the main pre-amp or power amp, or power supply. If you can turn the bad sound down, it's before the volume control and it's unlikely to be in the power amp section. If you can't turn the bad sound down, it will be in the power amp section.
Remember stereo amps are two mono amps joined together. So the two channels have separate parts for each channel. However some use IC's that have both channels running in them, they can be suspects in this case.
Jan 11, 2016 | Marantz Audio Players & Recorders
When installed, amp gets power but produces no sound
If you have a small mom and pop shop in your area. I would have them check it out. You might have gotten lucky.
Mar 28, 2014 | Sony Exm-502 Mosfet 2 Channel Stereo...
My Technics SUV 660 is making a crackling and popping sound regardless of where the volume is. It does reduce once the amp has been on for an hr or so. Also the speakers are not consistantly on. Any a
If the sound is on both channels then it's probably a device that is connected to both channels. I don't think it's the power supply. I rather suspect it's in the power amp section, since it's not affected by turning up the volume. If the amp uses one of those STK devices as a power amp, it could even be that.
Image of an STK power amp below:
Feb 17, 2014 | Audio Players & Recorders
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
Bxi 1606d amp it turns on power up but no sound
Well i sounds like your amp is shot. Or you have the subs wired incorrectly to the amp. Each amp is different in stability with ohm loads and each amp performs differently at each load. Sounds like it was wired at the wrong ohm load in the past or it came defective from factory. Definately send it back if u just got it.
Jun 09, 2009 | Hifonics BXI 1606D Car Audio Amplifier
My amp overheated on a Klipsch promedia 2.1
Sounds like your speakers had too many watts sucking from an amp that couldn't produce the power to feed them.
What is the max watt power output rating for your amp?
Compare the amperage of all the speakers combined and make sure they are 15% lower that the rating on your amp. Be sure to include the sub in your totals.
Chances are you've blown the power supply on your amp.
Have you tried any of these checks yet?
Mar 27, 2009 | Gem Sound SUB-650M Speaker
Power yes but no sound from my kicker amp
the i c sound have damage now you need to take it to a technician let them change it
Dec 15, 2008 | Audio Players & Recorders
Kicker DX350
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Sep 22, 2006 | Kicker DX350 Car Audio Amplifier
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
