Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water dripping in the refer, from above, everything else seems ok
It was very hot and humid, had both setting refer/freezer on minimum coldness?
    Scholar:
  • 56 Answers
This may not be the problem now but, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
My frig freezes top and also spoils coleslaw freezes water beer tried everything
First, call your fridge vendor for service.
*** the following is for information only. ***
* You need a full defrosting as there is ice in your cooling coils.
* Move food items to another refrigerator.
* Do a complete DEFROST of the box. (unplug it.) Expect it to take 4 or more hours. You must wait till all water stops dripping out of the fridge. Keep checking the lower defrost drip tray at bottom of fridge. Dump out water from tray as needed. DO NOT you a hair drier or any other heat source! The heat will warp the plastic. Use a small fan to gently blow into the freezer section.
* DO NOT use an ice pick or sharp object to remove ice! Just let everything melt. (The problem of ice is inside the coils)
* Plug in Fridge but don't put any food in. Set dial temperature to the Mid range setting. Set to freezer venting to normal. Set the refrigerator to mid range. Let it cool down to 0 - 10 degrees and start making ice (in ice maker) If it does not cool down to at least 10 degrees F then call for service. Suspect bad thermostat, Blocked condenser coils, Bad pump, etc. Qualified service tech required to repair.
* Cooling okay? Reload food but don't stuff it in. Leave space between the walls to allow cold air to flow around foods. It will take a day or so to cool down food properly. Note: I may take longer if this fridge is near a heat source like a Hot water heater, Oven, Range, Steam radiator, etc.
* If your still icing up in 2-3 weeks. Then check if the coils are icing up. Defrost is not working. This needs to be checked by a tech. Have him perform annual maintenance.
* Check door seals. Kids leaving the door open? High humidity? * Note how everyone uses the fridge; are they putting hot food in it? Open hot steaming food adds heat and humidity to fridge. Hot food with thaw out other frozen food and build up frost.
* Final, Have a Tech check your fridge. Have them perform maintenance and replace worn items as needed.
Aloha, ukeboy57
Mar 21, 2018 | Refrigerators
LG FX28977ST the freezer only gets down to 32 degrees and the refrigerator only gets down to 43 degrees. It seemed to work fine until two days ago when it quit making ice and the ice cream got soft.
First, I'm not a LG Technician. Call your LG vendor for service.
Aloha, ukeboy57
Mar 12, 2018 | LG Refrigerators
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Water dripping from inside rear of fridge compartment of GE-TBX series
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
May 27, 2012 | GE Refrigerators
Water dripping from top rear center of refer section. icing up and dripping, about a cup a day. seems unrelated to icemaker operations or humidity. What direction do numbers mean when setting temp for...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | KitchenAid Refrigerators
Water dripping from under feezer, have ice maker, shelves get soak and wet. model 71182100
Check to see if your refer has a climate controll ie: humidity setting, some models of refers swet when the humidity is high, if it doesn't have this setting turn your freezer setting down alittle. GL hope this helps.
Jun 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
May 26, 2009 | Maytag Admiral Top-Freezer Refrigerator
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
78 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
