I have a WRT110 router. I bought it in 2009. When I use my cordless 2.4Ghz phone, there is a poppping noise that does not go away no matter where I am in my house. How do I fix this?
  • 19,396 Answers
Hi. You usually cannot fix this problem. The problem is common to the fact that many devices abuse of the allocated spaces in the 2.4 GHz ISM band, that is the band used by all home devices. As a result several home devices invade the Bandwidth space allocated to the IEEE 802.11 Wi-Fi network, that is the band used by your router. If there is disturbance on the phone, this means that when phone is working, the interference is also affecting your router, making network communication slower. As an example check the diagram below. I draw it for a sudy on this very same problem. The blue line is the centre frequency of Wi-Fi channel 6, while the red lines are the center frequencies of a known brand (I will omit) 2.4GHz home video transmitter. All you can do to fix the problem is calling the phone manufacturer or the retailer complaining about the problem, and get a replacement. This unit can be set from factory to trasmit on different channels. If the phone is under warranty and you make them aware of the problem, they can send you a unit that does not interfeer with router wi-fi channels. If phone is not under warranty, then there are two ways out. 1)Check on the phone manual if the phone can be set to different channels. Phone of this kind usually do not have such a manual setting. 2) Force the router to operate on a specific channel. This is not a great solution as Wi-Fi networks are set to operate on the channels assigned to your regions. All the wireles devices may need setup according, if the network is forced to a single channel, connectivity may be slightly affected. 3) Most phones have a micro switch that can be set to select among different 2.4 GHz network channels. If present this is placed on circuit board, and phone must be taken apart.
Posted on Jun 07, 2010
  • tcser60 Jun 07, 2010
    Would getting a 5.4 GHz or newer frrequncy phone help?
  • Ginko
    Ginko Jun 07, 2010
    Re:Would getting a 5.4 GHz or newer frequency phone help?
    If the problem is caused by interference with router transmission, and not by a faulty router or by another defective device (eg. a Microwave), then this can fix the problem for sure, naturally assuming that the router is a G or G+. N routers transmit on 5.4 GHz, but should not normally interfere with other devices.
    Test if the problem is interference by typing router IP in Internet explorer to access the router control panel (refer to router manual), and temporarily disable router wireless. If problem persists, the the interference is not with the router.
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Aug 23, 2011 | Nintendo Wii Console
Why do all three of the cordless phones (the base phone and two handsets) make a clicking noise?
I am not sure what clicking noise you mean, but if it is constant clicking in the earpiece about once or twice a second it may be interference from a nearby wireless device such as a laptop or microwave, or a wireless router. Try moving the base station away from any such objects.
Mar 01, 2011 | RCA 25255RE1 2Line Cordless Expansion...
Trying to connect to wireless Internet and got error code32002 while updating
Dec 29, 2010 | Nintendo Wii Console
I already have a Modem provided by my ISP. I bought a linkSYS range plus WRT110 for better wireless connectivity.. Can anyone please explain how to use new router step by step???
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 23, 2010 | Linksys RangePlus Wireless Router WRT110 -...
CANT ACCRS WIRELESS ROUTER WRT110 BY LINKSYS CISCO
Sounds like the router needs to be reset..
Before you do a reset try to login to the router by typing 192.168.1.1 in the webrowser ..
If that fails then look on the back or under the router and there is a reset button. Press and hold for 10 sec ... The let sit for a min or 2 then try logging into it..
Note: That the router will have to be setup again. Default login admin for the password .. don't enter any usernames
Jul 22, 2010 | Linksys RangePlus Wireless Router WRT110 -...
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Dec 01, 2008 | Lands Phones
Computers & Internet Logo
David Payne
David Payne
