Question about Amana SXD524VW Side by Side Refrigerator
Refrigerator regulator how can i make the refrigerator cooler..how can i regulate it to be more cooler
  • Amana Master
  • 909 Answers
Inside the fridge compartment, there will always be a thermostat or mechanical flap. It will indicate cold: colder :very cold or similar to that. If it is an electronic fridge simply select a colder temperature.
If it does not respond over a 3 to 4 hour period, then something is wrong and it would need to be looked at..
Posted on Jun 07, 2010
How do I replace the freon in my Magic Chef Wine Cooler?Thanks
Freon is R-12 refrigerant. Regulated due to involvement in ozone depletion. Which means EPA licensing and you can't just buy it at Wal-Mart. If it's a recent model, it'll contain R-22 refrigerant. Look for a label that tells you what's in and capacity of system. You can buy R-22 refills at box stores but be sure the carrier oil is compatible. However a small cooler might not have been designed to be serviceable. Anyway look for two plastic screw caps for high or low side then use a pressure gauge for car AC from Wal-mart, compare two pressure
s.
Dec 11, 2014 | Cars & Trucks
What is my clearance regulations for
Hello Donna;
My name is Peter. I am a retired field service refrigeration technician.
The critical clearance, especially with under the counter units is in the back. You need extra space between the back wall and the heat coming off the compressor. I like to see 3" minimum. The more the better. If you are not getting sufficient air flow in the back then, your cooling condenser coil fan will constantly run in a effort to dissipate the heat.
Most manufactures recommend 1-1/4" minimum on the sides.
Nov 06, 2014 | Soleus JC-128 Wine Cooler
Front fender rubes on voltages regulator cooler when use front brake
This is strange. My first question is just how big is this cooler on the voltage regulator? It has to be some aftermarket addition because Harley does not put coolers on the regulators, the regulators are designed with cooling fins on them. Secondly, has any modifications been made to the original front end or fender? The Super Glide came with the same front end as a Sportster for all practical purposes. Lastly, with the engine off and the transmission in neutral. Hold the front brake and rock the bike forward and backwards. Feel for any looseness in the neck bearings or anywhere else in the front end. Also, look for cracks in the triple trees. If you feel it "klunking", the cause needs to be found and corrected immediately. This could be a very dangerous situation. Personally, I would not ride the bike until I made certain that the bike was safe to ride.
Good Luck
Steve
Mar 31, 2011 | 2000 Harley Davidson FXD Dyna Super Glide
Can the T-49F be converted from freezer to refrigerator?
Anything is possible so Yes... Although I wouldnt recommend it. The price to have a qualified technician do the job would reach very close to the cost of a new reach-in cooler and it could put a bit of a burden on the compressor. You are better off selling the freezer and purchasing a cooler with the money from the sale. It would involve one of two fairly large scale jobs. 1. The recovery of the refrigerant and installation of a CPR (Crankcase Pressure Regulator) with some wiring changes and adjustments... Or 2. The replacement of the compressor and capillary tubing.
Dec 26, 2010 | True 49 cu. ft. / 1388 liter Commercial...
I have a BeverageAire keg cooler. I just put in a new CO2 cartridge and keg. The beer is not tapping...barely dripping from the tap
two things to check first at what pressure is the regulator set too? should be i thaink about 4 pounds. also what is the temperature inside of the cooler could the lines be some what frozen?
Jan 30, 2009 | Refrigerators
No flow from keg
when was the beer hoe last cleaned? also have you checked the regulator on the tank......disconnect all hoses, and make sure all cloggs are cleared
Jan 01, 2009 | Danby DKC645BLS Compact Beverage Cooler
Installing a R232-HBF REGULATOR -What's up with this screen/vent deal? Will mosture affect it?- thank's
Most all regulators require a differential in pressure to work. To get a differential, you need to have gas pressure on one side of the diaphragm and atmosphere pressure on the other side. If you have high moisture, you can either effect the differential pressure, cause a freezing condition in the regulator in cooler weather or subject the regulator to premature failure due to corrosion. You did not explain if this is going to be used in a high moisture area or not. Can the regulator be vented to a low moisture area?
Dec 05, 2008 | Heating & Cooling
Wine cooler temperature control
toatlly normal operation, realize that the machine needs to shut off/ on to regualte temp, new electronic thermistors are sensitive enought to detect miute temp flux, i wouldnt be concerned about this
Feb 23, 2008 | Refrigerators
Freezer in gargae
Refrigerator Freezers are controlled by the refrigerator temperature and NOT the freezer temperature. Move it to a warmer location.
Dec 10, 2007 | Nor-Lake Norlake Refrigeration 4' x 6'...
Amana SXD524VW Side by Side Refrigerator Logo
234 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
