Question about Microsoft Windows XP Professional
Error display settings
Please help me again my computer got a problem in times i try to refresh it theres an error appairing it says YOUR CURRENT SETTINGS PROHIBIT RUNNING ACTIVE X CONTROLS ON THIS PAGE.AS A RESULT,THE PAGE NOT DISPLAY CORRECTLY..what shall i do please help me..thank you..
    Sergeant:
  • 269 Answers
Ok open your browser, top of page go to TOOLS, then INTERNET OPTIONS, then advanced. go down that screen and activate the active x controls .
Mel
Posted on Jun 07, 2010
Testimonial: "mel,thanks a lot for your help i appreciate it much...godblesss and more power to fixya"
I keep getting an error occurred please try again later
Just refresh or reload the current webpage or open a new browser and close the old,
Jul 01, 2010 | YouTube Videos
Help me please my minolta cf 2001 is shown the code- c13cb
Enter in service mode:press meter count key and press Stop key-0-Stop-0-0-1.Select the trouble parts if appaire on touch panel,or select rhe counter window and press the trouble parts.If appaire trouble window press and in this location appaire all trouble and error codes description and the malfunction location.
Nov 20, 2009 | Office Equipment & Supplies
Screen shows different colour grids when starting then goes black with message in right corner "out of range"
Hello ssi1,
This happens when your screen resolution is set to something higher than what your monitor can display. For example, if your monitor supports resolutions of up to 1024x768 and your video card allows you to crank it up to 1600x1200, doing so will give you an error. Another reason you might get the error is if the refresh rate you selected a certain resolution is higher than what your monitor supports. The monitor can't "sync" with the video card, so it just gives you that "Out of Range" error.
However, the first thing to do is check that the cable between the monitor and PC is plugged in all the way and is secure. If possible, try using another cable and see if this helps.
Next, either change the refresh rate, or change the video adapter settings, or both.
To change the refresh rate:
1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
2.
Right-click the desktop, click Properties, and then click Settings.
3.
Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
4.
Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties. )
To change the video adapter settings:
1.
2.
3.
Click Advanced, click Adapter, and then click Change.
4.
Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
5.
Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
6.
Click Standard Display Adapter (VGA), and then click Next.
7.
Click Yes, click Next, click Finish, and then click Yes to restart the computer.
8.
After the computer starts, right-click the desktop, click Properties, and then click Settings.
9.
Click 256 colors, click Apply, and then restart the computer.
10.
After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
11.
Click Device Manager, click View devices by type, and then click Display adapters.
12.
Click Standard Display Adapter (VGA), click Remove, and then click OK.
13.
Install all updated monitor drivers.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free holidays, meals, haircuts and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
Apr 24, 2008 | Computers & Internet
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
TFT Problem
This LCD can work at 75 Hz refresh rate, btw much more healthy for your eyes, you can change it accessing Control Panel -> Display -> settings -> Advanced -> Monitor -> Screen Refresh Rate -> select 75 Hz.
Dec 07, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Notebook lcd screen flickers and goes white
The refresh rate may cause this problem sometimes...
Try this
Right-click anywhere on desktop->Properties->settings tab->advanced button->monitor tab->screen refresh rate drop down list..Chose the refresh rate at which the screen will not flicker(try em' one by one)
If it doesn't work please post a comment and await reply before rating...
Oct 19, 2007 | Audio Players & Recorders
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Microsoft Windows XP Professional Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
