Question about Video Game Consoles & Games
I just got my wireless adapter. iv plugged it in. the red light comes on at the back. but i cant get onto xbox live. it says the wireless network isnt plugged in
    Problem Solver:
  • 15 Answers
The light should be green, a red light means ready to connect. First try to unplug it and plug it back in and make sure your wireless network is setup correctly. Go to your Network Settings, and check to see if it can detect your wireless network. If you have any security setup on it, make sure you input the key.
Try these steps they are from the microsoft website so hopefully it will help you out.
* On the Xbox Dashboard click the System tab, and then click Network Settings
* Select Edit Settings, Select the Wireless mode setting
* On the Select Wireless Network Page select your wireless network (if more than one appear, check your router configuration for your SSID, that is the name of your network)
* At this stage, if you have wireless security configured, you will be required to enter a WEP or WPA key. Again, check your router configuration for these details
* You should now be able to connect to live, if not, see the troubleshooting section.
Posted on Apr 10, 2008
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you successfully connect to Xbox LIVE, you'll see this screen:
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
Tip
How to connect to Xbox Live wirelessly
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
on Jan 25, 2010 | Video Game Consoles & Games
Trying to connect to x box live. just bought the
Okay so here we go!
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
Jan 18, 2010 | Microsoft Wireless Network Adapter Xbox...
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay so here we go!
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay so here we go!
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
I cant connect to xbox live
The red meant it was ready for configuration. If there is no light it means it is not receiving power. Try plugging it in again, or plugging it in to a front USB slot. If it still doesn't work your adapter has a defect and should be replaced.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
Need help connecting xbox live to the internet, have the wireless router but nothing is successful
Okay so here we go!
Dec 29, 2009 | Microsoft Xbox 360 Console
Having problems hucking up to xbox live
Okay so here we go!
Dec 25, 2009 | Microsoft Wireless Network Adapter Xbox...
Red Light On Wireless Adaptor For Xbox Live
just do port forwarding in the router and port number of the x box OK try it
Apr 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Video Game Consoles & Games Logo
57 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
