Question about Zanussi ZBF360X Electric Single Oven
F08 message on Zanussi Oven
I've run a self clean on my Zanussi ZYB594 and I have an F08 error message and the door wont open
SOURCE: Door won't open
Try holding the Off/Cancel button.
Posted on Apr 14, 2007
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
SOURCE: oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Posted on Feb 28, 2009
  • 10865 Answers
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
SOURCE: The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Posted on Aug 21, 2009
GE wall oven JK3800SHSS. Started clicking loudly during last 5 mins of Self-Clean. Ongoing clicking and running fan. How do I diagnose/fix this?
what was the error code?you should never self clean your oven before any big holidays,for reasons like this, if it takes out a part the part most likely will have to be ordered and the last day they take orders at my parts store is monday before thanksgiving so if it's your clock and you have to order it you might not have it for thanksgiving so hopefully you just have a bad latch assy. and you can get it fixed before the holiday,from what i've seen i will never self clean my oven,i use easy off and scrub it,the oven gets up to 1000 degrees and it damages the electronics in the oven.the clicking you hear could be the latch assy. unplug the oven.open the door and see if the hook part that locks into the door isn't jammed,i just went out tuesday to change a latch assy and that part was jammed,the rod that goes from the motor and to the door latch was hitting the metal part of the latch that bolts to the frame and i couldn't move the hook part or catch at all and the motor was clicking trying to move it,i had to lift the top of the stove,bend the body of the catch assy. so the rod could move freely and that fixed it.but using the self clean short lives the oven and it can damage the latch or the clock assy.send the error or just goggle it and it will tell you what it is.
Nov 13, 2017 | GE Ovens
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Kennmore self clean ultra temp electric oven model c968-68523-2 .is a 2001 year modelon self cleaning aspect ,after moving the door lock the message board up above says "dr" and heatdoes not occur .
Change door lock many range's have micro switches mounted on a plate that are cam operated there can be up to 4 switches One of them or the motor that tuns the cam has failed or ajar this explains why error saying Door is open Model # you have supplied is not a good # please re send
Jan 30, 2017 | Ovens
Self-clean-mode not working, I get the "door" error message
are you sure it is an auto lock door and not a manual locking type .
Oct 22, 2015 | GE Ovens
How do I fix error code f08 on a zanussi zpb 120 built in oven
Fo8 is heater fault. Check element first
Nov 17, 2014 | Ovens
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Went to turn on self cln,
Hi
Thanks for using FixYa. F5-E1 error indicates that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Zanussi ZBF360X Electric Single Oven Logo
297 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
