Question about KitchenAid Food Mixers
Need instruction manual kitchen aid mixer model k45ss
5 Suggested Answers
  • 16 Answers
SOURCE: need kitchen aid K45SS manual
Just go to Kitchenaid.com and type in your model number and you can download the user manual and/or parts diagram.
Posted on Mar 21, 2009
hslincoln
  • 235 Answers
SOURCE: kitchen aid mixer model K45ss motor just quit
Hi LCHESNEY, it sounds like you’ve got the mixer apart already to do your voltage checks. So my guess it that you’ve already determined that that (speed) Control Plate Assembly is not good and need to be replaced. Since you’ve already disassembled your mixer once I hope you have your mixer’s Parts List manual on hand, but if not, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Find Illus. No. 25, Control Plate Assembly, Part No. 240904-2.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able replace your Control Plate Assembly.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 22, 2009
  • 56 Answers
SOURCE: Kitchen Aid Manual for RRK90 mixer I need one
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Posted on Mar 16, 2010
SOURCE: kitchen aid k45ss mixer plug i in and it doesn't do anything ?
check the brushes
Posted on Dec 04, 2011
Kitchen Aid Classic Stand Mixer beater stops when it touches anything.
Very much the symptom of a worm (follower) gear needing replacement. Three are videos of this posted on the net and you can find the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 09, 2013 | KitchenAid K45SS Classic Stand Mixer
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer leans forward too far, causing the mixing attachments to rub on the bottom of the bowl instead of rotating just above the bottom of the bowl. how do i fix it?
Is this for a "tilt neck model? If so, the manual suggests that there is a small screw in between the base stand and the "neck" of the mixer. You should be able to screw it in or out to adjust it. Good luck!
Oct 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid growls at slow speed
Hello again, BCPSBT. I’m sorry, but I’m just a little confused because neither the Part List nor the Owner’s Manuals go into any detail about changing/replacing the lubrication grease in your mixer, so I’m not sure what you are referring to when you say your system ‘times out’ when you get to page 10 when you attempt to download it?
The Parts List manual is only 8 pages. Are you perhaps attempting to download the Owner Instruction and Recipe manual instead, which is much longer?
The reason you need the Parts List Manual K45SSWH-0.pdf (2730.37 KB) is to see the ‘exploded views’ which will aid you in the disassembly and reassembly of your mixer. The best instructions for regreasing you mixer are from these two websites:
I’m sorry I don’t have more specific step by step instructions to offer you. Sometimes you have to step out in faith and trust that you can actually accomplish the work yourself.
I wish you good luck in completing your ‘oil’ change.
Good luck and have fun. I hope this provides a little more clarification. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
May 07, 2010 | KitchenAid K45SS Classic Stand Mixer
Need kitchen aid K45SS manual
Mar 20, 2009 | KitchenAid Food Mixers
My kitchen aid mixer makes a clicking sound when it is on and will not mix properly. It spins, but sounds bad.
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Mar 11, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
Jun 01, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
