Question about Microwave Ovens
I want to pressurise/top up my flat cold water system by using a pump with the specifications listed below,ieincomming water disconnected,where the 1/2inch pipe comes in there is a hose connector.I will connect pump to hose connector.There is no stop tap ,so I have to ask these questions,before buying the pump. JABSCO PAR MAX 1.9 (12volt) PRESSURISSED WATER SYSTEM PUMP JABSCO PAR MAX 1.9 (12volt) PRESSURISSED WATER SYSTEM PUMP Click here to enlarge Pressure switch cuts in at 1.0bar (15psi) - cuts out at 1.7bar (25psi) Efficient, high-flow, self-priming pump. * Multi-diaphragm design self primes to 1.8m vertical lift, can run dry without damage. * Supplied with snap-in ports for hose or Hep20 connectors. * Quiet running * Motor protected by automatic thermal overload cut-out Includes bypass feature to provide smooth, quiet flow * No need for accumulator tank * Output: 7 litres/minute (1.5 gallons/minute) open flow * Connections: for 13mm (½?) bore hose or Hep20 push-fit connectors CW193
  • 909 Answers
If i read you correctly, you want to uprrade your flat cold water pressure. Truthfully, i dont think it is allowed as most of these places are under sectional tiale. Also, it will need to be connected to the outside mains pipe. In flats one pressure feeds all. Cant remember seeing a single flat having its own pressure pump.
Posted on Jun 07, 2010
  • mwiseman96 Jun 07, 2010
    Its allright,you say sectional tital,does not apply here,since flat is council,with my own water bill,the water I can get 100l at a time from a neighbour.I can assume with the above pump when I turn on a tap
    the pump will on and give water.
    What I cannot understand is why is there not a "stop tap"/stop ****",if there was a water leak how can
    a council tennant be expected o turn off the water?I am on ground floor!Any ideas..Posting again.
What material is usually used to transfer heat around central heating systems?
Water. Water is a good conductor of heat. The boiler heats the water, a pump circulates it around the system and through the radiators where it loses heat. Cooler water returns to the boiler for re-heating.
http://www.waermecenter.de/
Jun 16, 2015 | Microwave Ovens
How do i deforst chicken breast
Put in ziplock bag. Submerge in cold water for about 1hour.
Dec 03, 2012 | Microwave Ovens
Plumbing in water supply to fridge.
if this is for ice maker this is how its done. run the line through the floor in back of fridge to a cold water pipe. closest to where fridge sits.
  • Turn off the cold water supply to the pipes.
  • Attach a pipe clamp to the cold water pipe.
  • Screw a packing nut into the cold water pipe. Turn the packing nut until it punctures and taps into the pipe. Attach ¼-inch copper tubing to the outlet valve on the packing nut using a compression nut. Make certain the valve is closed before you secure the packing nut.
  • Attach the copper tubing to the intake connection using a compression nut. to back of fridge,
  • Turn on the cold water supply.
  • Turn on the outlet valve on the packing nut.
  • the kit should have directions with it. good-day !
    Aug 20, 2011 | Microwave Ovens
    My GE Monogram ZDIS15CSS ice maker fills the bin with water but does not pump water over the plate to produce ice. We did drain and shut unit down for 2 weeks and it would not start on our return. Can...
    I would check the ice level sensor... it is shown on page 9 of this manual...
    http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60440.pdf
    If the sensor thinks that the bin is full it will not do anything...
    That is why that would be my first area of interest..
    heatman101
    Mar 24, 2011 | Microwave Ovens
    I have a replacement magenetron and diode for a GE Profile undercabinet microwave. Can you share the step by step instructions for replacing it? Model number JVM 3670
    Disconnect the power source.
    Remove the cabinet to reveal the wiring.
    Locate the large transformer. Next to the transformer is the magnetron and diode assembly. MAKE SURE THE CAPACITOR IS DISCHARGED AS LETHAL VOLTAGES ARE HERE!
    Disconnect the diode and remember where the connections came from, (a phone camera is useful for this job). Remove the magnetron.
    Replace the magnetron and fit the diode pack.
    Replace the cabinet and test by placing 1/2 litre of water in the machine, having first measured the temperature of the water.
    Microwave for 1 minute.
    The water should have increased in temperature by at least 10degrees Celcius. If it has, it is to specification and you have repaired your microwave oven.
    Dec 28, 2010 | GE Profile Spacemaker JVM1871 Microwave...
    I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
    Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
    Dec 26, 2010 | Microwave Ovens
    LG refrigerator model #LRFD25850TT water dispenser no longer working
    Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. Or use a hairdryer on the inside of the door below the dispenser.
    I need to find an owner's manual for an emerson microwave oven model # mw8111ss Thanks Ruby
    Link below to download,
    http://www.emersonradio.com/owners/MWO%20manual/MW8111SS%20Owner's%20Man
    Master link below, if the top one fails look in the blue listings, about 14 down from top.
    Aug 21, 2010 | Microwave Ovens
    The dishwasher will not drain during the normal cycle. I turned the power off and removed the drain hose and the water drained out. I disconnected the drain hose from the sink drain and was able to...
    Can you here it drain pump when it time to drain. If you do not Then your pump is bad or the control board is not sending a signal to the pump. To see if you get a signal to the pump you can use a electrical tester to see if you get current.
    Jan 06, 2010 | Microwave Ovens
    My kenmore he3t washer sometimes fills with water when off.
    This can happen if the water inlet valve begins to go bad. The valve has electronic controlled solenoids that open and close to turn the water source on or off. These solenoids go bad from time to time, or the diaphragm inside the valve becomes clogged with sediment and does not close properly.
    Another cause can be the pressure switch malfunctioning. The pressure switch determines the water level inside the wash tub and shuts off the water inlet valve when the appropriate level is reached.
    Any easy way to determine WHICH component may be causing the problem is the leave the water source turned ON and unplug the washer. If the leak continues, the problem is the water inlet valve. If the leak stops, the problem is the pressure switch.
    To access either component, you need to remove the top panel of the washer. Locate the three screws that hold the top panel in place and remove. With the screws removed, the panel will slide back, then lift off. The water inlet valve will be loacted in the left rear of the washer (as viewed from the front). The pressure switch will be in the rear on the right.
    To replace the water inlet valve, follow these steps:
    1. UNPLUG the washer.
    2. Turn off the water source and disconnect the fill hoses from the back of the washer.
    3. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the valve.
    4. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
    The pressure switch is even easier. One connector plug and an air hose is the only thing attached to the switch. The switch is usually snapped in place along the interior cabinet wall with no screws holding it in place.
    Replacement parts can be purchased on line at any of the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    All these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also include helpful exploded view diagrams of your washer to help with locating parts and assembly.
    I hope I've given you enough ideas to work with in narrowing down the cause of your symptoms. This is generally a very simple repair, that isn't very expensive. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
    Dec 22, 2009 | Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
