Question about Frigidaire Electric Dryer
It doesnt want to blow hot air
It seams to work except it isnt blowing hot air there is air it just isnt hot and doesnt dry the clothes
    President:
  • 1,430 Answers
It could be several things the heating element , thermal cut out, thermal fuse. Most of these parts are very inexpensive and all are easy to replace. There is a video at http://appliancehelponline.com/edryerelementvideo.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles. This tutorial should be very similar to your model
http://appliancehelponline.com/electricdryertroubleshoot.html
Posted on Jun 07, 2010
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
1997 jeep wrangler will not blow hot air from heater,,, i replaced the thermostat ,, heater core isnt leaking, and my heater knobs are working,, it blows somewhat warm air , but doesnt get completely hot,
sounds like either the antifreeze solution is to strong [ shouldn't be more then a 70% mixture ] or the heater core is plugged [ some "stop leak" products will cause this.
Dec 29, 2010 | Jeep Wrangler Cars & Trucks
My Neff drier isnt drying my washing it is hot but the
Is the fan working? this blows air across the element which in turn cools the steam into water then pumps it out via pump,Hope this is of some help
Apr 13, 2010 | Neff V4380X0 Front Load Washer / Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Taking to long to dry
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Dec 08, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Frigidaire  Electric Dryer Logo
259 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
