Question about Microsoft Xbox 360 Console
My xbox keeps shuting down due to ventalation issues. Ive tried to clean the system with an air dust remover but i still keeps shuting off. My fan runs super fast all the time too.
    Problem Solver:
  • 6 Answers
Most likely, you have your Xbox in an area where it does not receive proper air flow and ventilation. Your fan is overworking itself from the dust and the heat of the area you're sitting it in.
Try moving your Xbox to a more open area after cleaning it, and be sure to let it dry out after using compressed air.
Posted on Jun 07, 2010
Why is my power supply light red and not green
That is the Red Ring of D*ath, meaning your console has overheated or is on the brink of completely dying. Try to ventalate your console as much as possible (place a fan by it, keep it out of a shelf. and if you can try to get compressed air and spray that into every opening to remove all dust.
Do all these steps before turning on your console again or it might be too late...
Oct 11, 2014 | Microsoft Xbox 360 Console
How do i fix over heating xbox360
It most likely means your xbox has alot of dust of the inside and the dust is slowing down the fans
To fix this either open the xbox and clean out all the dust or use a air compressor and use the air to get it out. I've trihe dustfirst and my xbox is running perfect, as for the second im not sure if the air compressor will take out all the dust.
Jul 23, 2012 | Microsoft Xbox® 360 Core System Console
Overheats after about 5 minutes then 2 lights apear red
Hello
This is a heat issue.The x box is shuting down on heat.
1 Remove console from area,disconnect all cables.
2 Using a can of compressed air,blowout the x box remove dust and dirt.
3 It may be a good idea to remove covers and blow off internal parts also
4 Relocate x box in a well ventilated area,remember to clear fan of dust also.
5 Reconnect x box and try it out.
You may need to reapply thermal paste to cpu,suggest taking it in for repair if you need to.
Oct 11, 2011 | Microsoft Xbox 360 Console
We have red rings flashing on our xbox 360live
Hello
The red rings are a cpu or gpu failure.Usually due to heat.
Power down x box remove all cables and remove x box from location.
Next.Clean as much as possible with a can of compressed air,remove as much dust and dirt as you can.You may need to remove cover to get to motherboard.
Also be sure all fans are moving free and clean.
Once this is done .Try x box.Locate in a well vented area.
Sep 22, 2011 | Video Game Consoles & Games
My fan keeps speeding up , then it slow downs what causes this? an how can I fix this?
which fan is doing this? Mostly likely it is caused by dust or overheating. Use a can of compressed air found at any electronics store to clean the dust out from inside the computer. If that doesn't solve the problem I would next try replacing the fan.
thank you,
Lee
Sep 21, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Hp proliant server is shutting down in every 4-5 hours due to cpu over hitting. its internernel health indicator on chassis is red & externel is Amber. One fan of one smps is not moving.
Heat up is mainly due the clogged heat sink and fan etc, which requires to be cleaned. It is strongly recommended that you clean the heat sink etc yourself or seek help from authorized professional at the earliest to avoid any damages to the PC.
If the system fan is not working properly, it may be due to dust inside the fan. This could be due to faulty fan or it may be stuck due to dust etc. In this case, using a compress air for cleaning would be helpful. This will result in heating up of the system and the processor/ graphic unit may burn. Try to clean the fan. You may use Compressed Air can to remove the dust etc. Cleaning and lubricating liquid available commercially can be used to smooth the inside rotating parts of the fa. Also, do check the fan power connection. Give it a try and try to make sure the fan is running. (if not it needs replacement). If you find it faulty, you may find and replace the fan by removing the old/ faulty fan by removing the 4 screws and installing the new one.
Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
Jul 29, 2011 | HP Compaq ProLiant ML350 G3 Server
I have the old xbox 360 and when i play it the fans still work but it keeps over heating and the only way to play it is to have a house hold fan behind it why would that be.
The cpu needs cleaned you can open it up and do it yourself its simple and dont cost anything the problem is over time dust builds up on the cpu it has no system to keep dust out if you clean it out it voids the warrenty but the system will run better or pay to send it in for service call 1-800-4my-xbox also you can try compressed air that wont void the sytem but most of the time it just moves dust around
Jan 31, 2011 | Microsoft Xbox 360 Console
Computer shuts down on its own
Most likely when a computer shuts down on its own it is because the computer processor or power supply is either overheating or is under powered.
Feel with your hand around the computer case and back of the power supply (has circular fan usually/ on off switch/ and a plug goes into it)
If it is very hot you will have found your answer.
Did you just install or upgrade a processor? If so you may need to check to make sure that there is thermal compound (artic silver, etc) between the processor and heat sync. This can cause overheating and sudden shut downs. If not move on
Is your computer in a small enclosed area? Try moving it to an area with more area for ventallation and cooling.
Do you have adequate cooling/fans? are they working? if not check power cables and may need to replace the fans or install more. You can buy and install case fans pretty easily
DUST. Are the fans and imputs dirty? Keeping them clean will keep the computer running cooler and help lower temperature and avoid shut downs. If your fans/imputs are dirty remove dust by using a can of compressed air, a vacuum made specifically for pc/electronics. or you may wipe them down with rubbing alcohol and a dust free cloth.
This should help Anthony
Jan 18, 2011 | Dell Inspiron 530 Desktop Computer
Overheating issue Sony GRT270P
Maybe it's wrong with your heatsink;youcan touch this:
http://www.laptopcpufan.com/sony-laptop-cpu-fans-c-7.html
Jun 27, 2010 | Sony (4-635-961-01) Laptop Heatsink
Toshiba P15-S420 srtange power problems
check in back side remove battery then clean it from dust then refix it.
Jan 10, 2009 | Toshiba Satellite P15-S420 Notebook
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
