Question about Kenmore 67082 Electric Dryer
I had a F70 error code on my Kenmore HE Elite dryer. In the manual it does not show a F70 code. I unplugged and let sit for a while now it will not even power up.
  • 15,935 Answers
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
Jul 27, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
My Dryer Kenmore Elite HE5 show the Code F70...
Dec 31, 2009 | Kenmore Elite HE4 Electric Dryer
What does the code f70 on a kenmore elite dryer mean?
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Please report back here what you find, OK?
Aug 05, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F70 and F71 code on Kenmore Elite
Jun 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 67082 Electric Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
