Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler vtwin 25hp erratic idol
I have a Kohler vtwin 25hp yard tractor that runs erratic after an hour or two of mowing. I started noticing the problem with a half tank of fuel, filled and ran great. On next mowing, replaced the filter and ran great for two hours and the erratic idol started again with a full tank. I've been religous in maintaining this tractor and has ran great for 5 years mowing a 4 acre lawn.
  • dsbarnes Jun 07, 2010
    Thanks Joe, I'll give it a shot.
  • 10,865 Answers
Hello. Go to any auto parts store and get a bottle of a fuel additive called seafoam. Follow the directions regarding how much to add. Run some of this treated fuel through the tractor for ten minutes and you will most likely solve your problem which is probably due to some residue moving through the carb. J.
Posted on Jun 07, 2010
    I also wanted to add, I noticed oil in the air filter and traces of oil in the bottom of the intake housing. Not sure if this is related.
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Craftsman tractor 917.273241 25hp Kohler, 48" cut. The clutch return spring will not hold tension more than a few hours of cutting. The temper in the spring end near the exhaust pipe from the engine to...
I'd be tempted to shield the spring from the heat of the exhaust - is there any way to pop rivet on a piece of aluminium sheet and bend it to not impede the operation of the clutch?
Aug 08, 2013 | Craftsman Garden
2166 stalls after it heats up
Sounds like you've got a bunch of debris around the engine, not allowing it to cool properly. I'd pull the shroud off the engine, and clean out any accumulated debris and clippings (considering your symptoms, I'd expect a lot of it. My preferred method is to use an air gun connected to my compressor - I don't like spraying under the shroud with pressurized water.
Sep 09, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Jul 09, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My cub cadet 2165 PTO clutch has no voltage getting to it to activate it. the normally closed switch is ok. could it be the relay? how do I test it?
on my cub the blades keep shutting down when im mowing . I replace the pto switch and it doesnt help .. got a recommendation
Feb 03, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Governor hunts
Pour vinigar and hot pepper sparkles into the gas tank and mix it with the gas. Then start it- the differance in the way it runs will be very noticable!
May 22, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
238 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
