Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Hello there, i'l like to make a question. my
Hello there, i'l like to make a question. my chain saw was for about 7 years with out use, but i storeged it with the blde up right all that time. now i want to use it, but it doesn't start. What can i do?. please i'll thank you.
    Brigadier General:
  • 4,088 Answers
If it had fuel mix in it all that time, plan on cleaning the tank, and replacing the fuel line and filter. The carburetor will need to be disassembled, cleaned and probably re-kitted. Clean the muffler and replace the air cleaner if clogged or disintegrated. Check for spark when the plug is removed. If everything looks good, start the engine and check for chain oiling by running at speed for a few moments with the bar tip near some cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Posted on Jun 12, 2010
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
Describe your sears 18"
if such problem happened when you didn't touch the throttle, then open the filter cover and take out the filter you may see the carburettor and then pull the choke, you may find the issue
Sep 21, 2011 | Craftsman sears 18" Chain Saw Chain (...
What kind of oil do i use to maintain the chain on the saw?
Hello there, I just used 30 weight non detergent on my Still gas saw years ago.Mainly because it got used so fast.You might check your local bicycle shop cause they have stuff that stays on the chain better($10.00 and up).Just keep the chain sharp and don't overload it. Most any hardware store will carry some kind of chain oil.You could call a saw shop and ask them as well.I burnt up the plastic chain adjuster once because the chain was to tight ,had plenty of oil but chain was to tight.About 1/8 gap or a little less at the bottom the bar.Unplug , wear gloves and pull the chain around the bar to check for binding. THANK YOU for choosing FixYa.com.
Jul 17, 2011 | Remington 16" Electric Chain Saw
No local Ryobi dealer; what other brand chains will fit my 18" Ryobi ?
Any saw service dealer can fit a chain to your saw. 'Oregon' saw makes bars/chains for about any saw made in the last 50 years or so. Just take the chain itself in to get a replacement. Good luck!
Nov 18, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chain slips
Your problem statement seems to be chopped off, but apparently, when you go to cut something, the chain just stops turning. Assuming that is so, remove the bar and chain, then wash out the interior of the clutch mechanism with spray carburetor cleaner. Let dry and re-assemble the bar and chain. Make sure the chain is being properly oiled by running the saw at speed with bar tip near some cardboard--it should leave thin line of oil after several moments. Make sure the chain teeth cut toward you on the bottom run of chain. Hope this helps!
Jul 07, 2010 | Husqvarna 18" 502cc Prosumer Chain Saw ...
Were can i buy a tension adjustment screw for a rcs4046c chain saw
Hello. Look in the yellow pages under chain saws. Any chain saw shop that sells Ryobi chain saws will have these screws in stock or be able to order one for you. Joe
please rate my answer as very helpful. Thanks
Apr 18, 2010 | Garden
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain saw chain replacement
Pages 6 and 7 are quite detailed.
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2004/NOUS2004_530165555-01.pdf
If you saw is not a Poulan PP4218AV you can find your manual here (chain installation should be similar):
CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
I hope this was helpful. Additional assistance can be found adding a reply below.
Lou
Jan 24, 2010 | Poulan PP4218AV 18" Chain Saw
Where can I get manual for model 358.355061 craftsman chainsaw ?
please tell us about the make(manufacturing company) of that machine,
Aug 07, 2009 | Garden
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
37 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
