Question about Kenmore Elite HE4 Electric Dryer
Brown marks are appearing on clothes after drying. These are not burn marks but rather something that is coming from inside the dryer.
I have the same problem. I have wiped the dryer several time with soap and water. I only found that it might be the glue on the felt gasket??? Dunno...
Posted on Jun 11, 2010
Testimonial: "I will try this fix tonight but it sure seems like the answer I'm looking for. Thanks!!"
  • AIE4HHO Jun 11, 2010
    ok... figured it out...the ducting which supplies the heat(in the back of the drum) is contaminated with lint. The lint is charred and introduced to the clothing during normal operation. The charred lint causes the stain(two to four inch long brown streaks) and then is passed through like regular lint. I've never seen the charred lint in the screen. In troubleshooting the "no heat" issue I'm having, I removed the ductwork in the back of the drum and it revealed the exact same color lint as the streaks on 95% of my whites. Resolution: UNPLUG the dryer. DISCONNECT ELECTRICITY!!! Take the back panel off. Remove all the lint. Take the heat supply duct off and clean. Replace it all in reverse order... on a scale of 1 - 10 the difficulty level is around a 2. I got the dryer 5 years ago and noticed the streaks a year ago. Good Luck
My clothes are leaving the dryer with streaks (maybe 4 or 5 inches long) that appear to be burn marks. Closer inspection of the inside of the drum shows that the back "wall" of the drum is off-center...
I have the same problem and read somewhere to replace the felt belts. We have done this twice and still getting the brown marks. I have found using Goo Gone and/or Dawn dish soap and scrubbing with a brush will take most of the mark out, re-wash and HANG to dry. I'm still looking for a permanent solution to this problem, as much as these dryer cost and you can't dry white clothes???
Jun 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Brown marks left on clothing.
You probably have significant lint buildup inside the machine. The lint gets burned by the heater and causes the dark marks on the clothes.
This could indicate a fire hazard!!
The solution is to disassemble the machine and remove all lint residue inside, especially in the heater area.
Apr 19, 2010 | Kenmore 62602 Electric Dryer
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Brown lines on clothes (whites and lights) from the dryer
you need the top seal replaced it is wore and clothes are getting stuck in the front seal...
if you are handy you can do it yourself...
Jun 17, 2009 | Frigidaire FTF2140FS Front Load Washer /...
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Frigidaire Dryer Model FLGB43RG
those "burn" marks if they have an arking shape to them are smudges from the felt that goes on the drum support above and bellow the door inside the drier. the felts wear out every five to seven years or so. easy repair. send me a model number and i could go into more detail. part numbers ect.
Sep 23, 2007 | Zanussi TC7114W Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
309 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
