Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Bridge router How do I put my router in bridged mode ?
  • 70 Answers
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Posted on Jun 07, 2010
5 Suggested Answers
tpvijay
  • 34 Answers
SOURCE: Bridging of a Zyxel prestige 600 router
Here are the information to configure Zyxel as bridge
http://www.zyxel.com/web/support_knowledgebase_detail.php?KnowledgeBaseID=3104&pid=20040812093058
With Regards,
TPV
Posted on Jan 27, 2008
SOURCE: Bridge mode
Comtrend ModemLogin: root Password: 12345
Posted on Oct 14, 2008
  • 49 Answers
SOURCE: d-link dir-625 in bridge mode
Try disabling the routers dhcp undet the network setting and make sure that the ip address is in range of your own network.
Posted on Jan 10, 2009
hichama9
  • 65 Answers
SOURCE: 2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Posted on Oct 30, 2009
How do I find the bridge mode in sb6121
The Motorola Surfboard SB6121 is a cable modem only - no router included.
You must have a router - after the modem - in the network if you need router duties.
There is no bridge mode in the modem. Bridging the modem basically bypasses the routing function of the device and passes everything on to the next device in line......the router in this case.
Since this modem does not have a router built in - it is always in bridge mode.
Feb 03, 2015 | Arris Sb6121 Docsis 3.0 Cable Modem...
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
May 21, 2013 | Cisco 878 GSHDSL Wireless Router for Small...
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
Do not know how to fix bridge mode
give the static ip to the wan option in the router then you get the bridge mode
Apr 16, 2009 | NetGear RangeMax WPN824 Router
How to put dsl-320T in full bridge mode?
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
May 18, 2008 | D-Link Computers & Internet
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
WGR614v6 - Bridge mode
This may provide some input for your request.
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=23547&action_code=5&highlight_info=16777285,88,115&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=18710634#__highlight
Dec 11, 2007 | NetGear WGR614 Wireless Router
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
1,091 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
