Question about Samsung LE40B650T2 40 in. Full HD Crystal LCD TV
HOW TO CONNECT MY TV PROJECTOR TO MY Samsung LE40B530P7WX 40?? THERE IS NO VIDEO OUT PUT!!
My samsung projector tv's light lamp keep shoting on and off what could be the problem?
http://www.youtube.com/watch?v=ARNVqW6qngE&feature=related hi there, above is the link to a video clip. Please watch it is the same idea in replacing the lamp for your Samsung TV. defective lamp need to be replaced especially when it manifest defects for you to enjoy your same old TV. Please rate and vote, good day
Mar 11, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How to connect galaxy tab to TV
Welcome to Fixya. To connect the Galaxy Tab to a Tv you need to use the cable below. The cable is color coded so make sure you connect it to the right port on the tv. If it is already connected use the TV remote then look for an Input or Source button then select Video or TV/Video
Connect your Samsung Galaxy Tab to your TV with this Original Samsung AV Cable. The 30 pin to composite video cable will allow you to connect your Samsung Galaxy Tab to your television or projector easily.
This will enable you to watch videos and picture slideshows stored on your device. Connecting the Samsung Galaxy Tab to your TV or projector with this cable will also allow you to use the sound from your television or surround sound system to give a richer, fuller sound.
If you have questions please let me know. Thanks for using Fixya
Mar 06, 2011 | Samsung Galaxy Tab Tablet PC
Ho do i connect my laptop to my flat screen samsung tv
There are 3 ways ways to do this from the left side of the laptop.
1) S-Video-out jack [Connects an optional S-Video device such as a television, VCR, camcorder, overhead projector, or video capture card.]
2) External monitor port [Connects an external VGA monitor or projector.]
3) HDMI port (select models only) [Connects an optional video or audio device such as a high definition television, set-top box, DVD player, or any compatible digital or audio component.]
Your TV will have one of those interfaces. You just need to look at your user manuals for both the Laptop and TV
Take Care
Oct 03, 2010 | HP Pavilion dv9000z Notebook
How do you connect the NEC VT560 to project tv pictures
if you have a cable or sattelite box, or a tv with a video output, connect the video output from the box or tv to the video input on the projector. if you have a tv without a video out, you cannot watch tv and change the channels on the projector.
Jan 12, 2010 | NEC VT560 Multimedia Projector
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
How to connect IBM T61 to my Samsung LCD TV 40'' 3xHDMI
If you have an s-video port you will need to buy s-video cables and a separate audio cable for sound. With HDMI you will only need 1 cable for both video and sound. Just connect your s-video cable to your s-video output ( your laptops quick reference manual should show you where your s-video jack is at ) and the other end to the back of your LCD tv video input ( consult your lcd tv manual )
Jan 02, 2009 | IBM Lenovo ThinkPadĀ® T61 PC Notebook
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
HP MP3 3222 Projector
you dont connect a projector to a tv. you connect a video source to the projector like a dvd player or a video machine.xbox 360 etc, the projector then projects the item connected to it, like your tv does when you connect similar items. The projector has a couple of inputs available to it ..this is why it is saying searching VGA and Composite video etc
Jun 14, 2007 | HP MP3220 Multimedia Projector
Samsung LE40B650T2 40 in. Full HD Crystal LCD TV Logo
211 people viewed this question
Henry  Thomas
Henry Thomas
