Question about Dell Latitude D600 Notebook
Can i adjust size of display as a cracked screen has blocked some
My laptop screen is cracked and has blocked some of my screen out (less than half) but the side where the start button is - can I adjust the size of myu display to fit in the section of screen i have? How do I do this without monitor position buttons???
  • amyrat Jun 07, 2010
    this isnt a dell laptop, dont know why it says it is...it is a samsung R519 with windows 7
    i know how to do that but its not convenient for me to do that at the minute, was just wondering if there was anyway i can change the display area temporarily :)
    Sergeant:
  • 356 Answers
Hi. The best thing to do is to get an external monitor and connect it to your laptop. Press Fn+F8 to show the display on your ext monitor.
^_^
Posted on Jun 07, 2010
Half screen
Sounds like a faulty screen, has the laptop been dropped or physically damaged? can you only see half of the screen? if the other half is black and one half "fuzzy" it's most likely that the liquid crystal display has been cracked/broken. The only way to resolve this problem is usually by replacing the screen which in some cases can be as expensive as a new computer :(
Apr 28, 2013 | eMachines Computers & Internet
Why is my screen opening at half screen?
not sure what half screen you are referring to
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
or if its actually half of the screen
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Aug 09, 2012 | HP Computers & Internet
Screen suddenly displays less than half of full size. How to expand to full view? Help!
Right click the desktop, properties, change the resolution to the appropriate size. If this does not work try using the menu accessed by the buttons on the monitor to do a auto configure on the correct size of the screen.
Mar 30, 2011 | Dell Computers & Internet
When i put the computer to max resolution, i get blue pixels flying around in the left of the screen!
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
hope this helps
Nov 01, 2010 | Acer 22" X223w LCD Monitor
Cant get picture to fit laptop screen
if you mean your desktop/screen saver
hope this helps
Oct 28, 2010 | Computers & Internet
Gouge in laptop screen. Less than half inch long
Hi:
is the display distorted under the scratch?
If it is, the problem could get worse. If your scratch is just on the plastic surface, the problem shouldn't get worse.
Oct 29, 2009 | HP Pavilion dv6000z Notebook
My IBM Thinkpad A21m was working fine, then all of a sudden, the display screen size is about half of normal. When I plug a desktop monitor into it, the screen is full size. What's going on?
right click on an area of BLANK desktop and select properties
Now go to the SETTINGS tab and check the resolution and adjust it to a little higher. click APPLY then OK
If all went well you should notice a difference If not report back to this post and w will see what else needs to be done
If it did make a difference then adjust it more if you need.
Aug 20, 2009 | IBM ThinkPad A21m 2628 Notebook
Tool, taskbars and text all shrunk to half normal size
Did you try Control Panel and Display, Setting tab and adjusting the resolution by moving the slider? That should take care of it.
Jan 17, 2009 | Dell Latitude D800 Notebook
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
Dell Latitude D600 Notebook Logo
126 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
