Question about Roxio Easy VHS to DVD for PC
Looking to uninstall Rioxio VHS to DVD, having problems. "Unable to find Certificate File"
    Sergeant:
  • 269 Answers
Try this windows clean up utility it should help
http://support.microsoft.com/kb/290301
Mel
Posted on Jun 07, 2010
Vhs to dvd transfer best way
You need a VHS to DVD converter hardware and software. This converts the VHS movie into DVD file format then you can burn this file to a DVD disc.
These video converters are available on the Internet.
Dec 04, 2011 | Televison & Video
I have installed, uninstalled, and reinstalled Roxio Easy VHS to DVD several times. I keep getting a " certificate is missing or corrupted please reinstall" message. I am thinking about...
When you use the Add/Remove Program tool to uninstall an application, Windows reads the installation log that was created when you first installed the program and relies on the information
contained in the log for direction. Problem is, this usually results in changes made to your Registry
being left behind.
Reinstalling the same application after a less than thorough uninstall procedure can sometimes
result in registry corruption and other nusances caused by file clutter left behind.
It's always good practice to create a system restore point before installing any new application,
which gives you the option of simply "rolling back" the system to its pre-install state. Absent that,
I recommend you not rely on Windows' Add/Remove Program tool to handle your uninstalling.
Instead, use a third-party utility that does a better clean-up job.
I've had good results with Revo Uninstaller. Revo offers a freeware version in addition to a 30-day
trial of it's Pro version.
Good luck, and I hope this helps :)
Jan 04, 2011 | Roxio Easy VHS to DVD for PC
I receive a error code 643
What Operating System are you using? If W7, then Creator 2009 is not compatible with it.
Re: Certificate file. It is part of the program that says it is OK to run the program.
If you only want Creator 2010, use Revo Uninstaller in the Moderate Mode to remove both programs. Sometimes they become intertwined and removal of one will screw up the other. That is why you should uninstall both.
Several people have used Revo successfully but it is no guarantee. If you have tried the full uninstall, then you have little to lose.
Just in case, copy the Creator 2010 disc to a folder on your computer and install from there AFTER you have prepared your computer like this. That should solve any issues with a bad disc or with your computer reading the disc. Of course if it is bad enough, you won't be able to do this.
Nov 03, 2010 | Roxio Easy VHS to DVD for PC
Problem with Roxio Easy VHS to DVD Upon double clicking icon on desktop, I get the following message: "Certificate file is missing or corrupted. Please re-install it." I have a 1 year old Dell...
Copy the following into notepad and save it as user.config
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<userSettings>
<Roxio.VHS2DVD.Properties.Settings>
<setting name="EnableUEIP" serializeAs="String">
<value>False</value>
</setting>
<setting name="UEIP_GUID" serializeAs="String">
<value>1beff98f-c0f7-45fd-b1d4-83647eb9e606</value>
</setting>
<setting name="IsFirstLaunch" serializeAs="String">
<value>True</value>
</setting>
<setting name="FirstLaunchDate" serializeAs="String">
<value>30/10/2010 5:16:39 AM</value>
</setting>
<setting name="PlaybackVolume" serializeAs="String">
<value>50</value>
</setting>
</Roxio.VHS2DVD.Properties.Settings>
</userSettings>
</configuration>
Create the following directory(s) in Users-yourusername-Appdata-Local:
Sonic_Solutions\EasyVHS2DVD.exe_Url_hhfgkb1u0ycf2w3tdzo0dhp3nidmxflu\1.0.1.21
Copy the user.config file into the 1.0.1.21 folder and run VHS to DVD - worked for me!
Oct 26, 2010 | Roxio Easy VHS to DVD for PC
Certificate file
Pretty much what it says. Some sw/hw come with, or has, electronic certificates of authenicity. If you have, say, reformatted since last use, you may have to reinstall the certificate (the sw/hw install file should do this, but in some cases you may have to register the product online to get the certificate).
Allan
Nov 13, 2009 | Roxio Easy VHS to DVD for PC
Daewoo VHS to DVD converter - disk only plays on the converter
The Disc needs to be finalised. Using the setup menu and disc info you select "finalize disc". I had the same problem.
Jan 12, 2009 | Daewoo DV-T8DN VHS VCR
Roxio Easy VHS to DVD for PC Logo
261 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
