Question about Altec Lansing ADA 215 Computer Speakers
Connected them to hp compaq windows vista. they won't turn on
Plugged into the green jack outlet and noticed that it mutes the computers internal speaker.
thanks for your help.
    Problem Solver:
  • 11 Answers
If it is happen for all the speaker then laptop fault dear.
Posted on Jun 07, 2010
I got this computer from my sons coach but it has a password on it how do i get pass that
Is it power on (BIOS password or Windows Password?
Clearing Forgotten BIOS Passwords (from Owners Manual Page 109)
CAUTION: To guard against electrical shock, always unplug your computer from
the electrical outlet before opening the cover.
Shut down the computer through the
Start
menu (see page 27).
NOTICE:
To disconnect a network cable, first unplug the cable from your computer and then
unplug it from the network wall jack.
Turn off any attached devices and disconnect them from their electrical outlets.
Disconnect the computer power cable from the wall outlet, and then press the power
button to ground the system board.
Remove the computer cover (see page 74).
5
Locate the 3-pin password jumper (see page 77) on the system board, and then attach
the jumper to both pins.
When you receive your computer, the jumper is attached to only one pin.
6
Replace the computer cover (see page 99).
NOTICE:
To connect a network cable, first plug the cable into the network wall jack and then
plug it into the computer.
7
Connect your computer and devices to electrical outlets, and then turn them on.
8
If you are prompted to press <F1> to continue, press <F1>.
9
After the Microsoft Windows desktop appears on your computer, shut down the
Start
menu (see page 27).
NOTICE:
10
11
12
13
Remove the password jumper.
Attach the jumper to only one pin so that you do not lose it.
Aug 05, 2014 | Dell Dimension 4600 PC Desktop
Using audio video jacks on my computer
Make sure you have the correct plug. The audio out is usually a green plug with a little picture of a speaker next to it. The microphone jack is usually red with, you guessed it, a little picture of a microphone next to it. If you're trying to get sound from your PC to your stereo, you want to connect the cable to the green PC jack.
Also, make sure your volume on the PC isn't muted. In the lower right hand corner of your PC screen, you should see a little speaker icon (click the arrow next to the other icons if you don't see it). Double-click that speaker icon and look at the volume settings. Make sure nothing is muted or set too low, then try again.
Hope this helps.
Mar 05, 2010 | HP Compaq Presario SR2050NX PC Desktop
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
I do not hear my music what do i have to turn on
In the system tray, check the speaker icon (to me it looks like a megaphone on Vista and Win7). A single left click will check if the speakers are set to a low volume or mute.
Also check if the correct drivers are loaded (there will be an exclamation point here if that is the case). Allow Windows to Fix the problem with Windows Update set to download and install updates.
If that is fine, check that the speakers are plugged in properly to the computer and themselves. If you have a multi-channel sound card and speakers, check your manuals. If you just need the single speaker out audio jack, it is usually colored light green. For USB speakers, try plugging them into another USB port or directly to the computer if plugged into a hub.
If the speakers need external power, make sure that plug is plugged in and the transformer is warm. If the transformer brick is cold after being plugged in to a live outlet, you will need to replace it (contact the manufacturer or read your documentation carefully to match the output voltage to the original). Alternatively get new speakers.
A final thing to try is in the control panel, under Administrative Tools, open the Component Services window. Stop any items related to your audio device and then restart them. Reboot the computer afterwards.
These are the most likely suspects and I hope this helps.
Dec 09, 2009 | Compaq Computers & Internet
I have sound when i plug in my mp3, but no sound for my computer
Be sure that the green plug is connected to the computer audio output jack which is color green. See also the volume of your computer and make sure that it is not muted.
Nov 10, 2009 | Compaq Presario 5000 PC Desktop
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
Speakrs don't work on new HP Pavilion desktop.
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
Apr 17, 2009 | Computers & Internet
No audio in monitor internal speakers.
Make sure the cable that goes from the monitor to the computers green audio jack is connected.
Check that the monitors speakers are not muted(see if there is an option to do that by pressing certain buttons on the monitor) ,finally make sure the sound on the computer itself is not muted or too low.
Mar 27, 2009 | Dell Microsoft Windows XP Home Edition
Compaq presario 773tu external speakers problem
You may have to download a different audio driver for your Vista OS.
Oct 18, 2008 | Microsoft Windows XP Professional With...
Dell Speakers not working on Compaq presario?
Shut down computer,plug in speakers,then power up computer.Computer should automatically install drivers,or give you option to install drivers from web.??
May 09, 2017 | HP Compaq Presario 2500 HP Pavilion ZE...
Altec Lansing ADA 215 Computer Speakers Logo
80 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
