Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
Kids broke pull cord
It looks like access to housing of cord is rivited to body or should I take apart more of the housing to get to pull cord housing its a briggs and stratton 6.75 hp for an ariens "21" thanks
  • 420 Answers
Remove the entire housing and do not drill the rivets unless you can replace them with the same size.
Posted on Jun 07, 2010
The plug prong broke on my Electrolux Epic 6500 SR vacuum. I cut it off and was going to replace it with a new plug. However, I mistakenly rewound the cord and it went all the way into the body.
You will likely have to install a new cord reel. Cord reels have a long tightly wound steel spring which can fly out causing injury if you attempt to take it apart.
Mar 04, 2017 | Vacuums
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
How do you get the door panel off of a 1996 Chevy Silverado when both the inside and outside door handles are broke.
If it's like most all other door panels, you have a couple of phillips screws in the arm rest, a screw behind the handle, (inside the vehicle), the window crank usually has a c=clip behind it, you can usually just push it out with a screwdriver. sometimes it's held there by a screw. The outer edges of the panel are held to the door by plastic rivits, just take a medium sized flathead screwdriver and pry it beteen the panel and the door, and slide it till hit one of those rivits, then just pull on the screwdriver thereby pulling out the rivits.
Apr 30, 2012 | 1996 Chevrolet C/K 2500
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Craftsman 917-377150, the pull cord broke and the housing to replace it is rivited in place, can I drill these out, but then what?
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Jul 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Door handle won't open door from exterior - inside door handle works
theres a clip or a rod on the handle that cud be brokes so u would have to take the door apart to find out
Feb 21, 2010 | 2001 Ford Explorer Sport Trac
I have a Ryobi RLT30CESN. The started cord broke
Dont remove the center screw out of the spring pully or the spring will fly out. you put in the cord while the spring is assembled inside. Take the housing off but do not remove the pulley unless the spring is broken. The string can be put in using needle nose pliers from the inside of the housing once it has been removed. once installed you wind the cord around the pully and then turn pulley untill you get proper spring tension. Once tension is achieved you fish the cord back threw the eyelet coming out of the housing and tie the handle to the cord. It is a really simple and easy thing to do but hard to put into words.
Nov 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
My neighbor just gave me a Troy Bilt 020207 power washer. It is 2450 PSI and 2 GPM. He snapped the pull cord rope. I looked at the pull cord cover and it seems to have 3 rivets holding it to the main...
sounds like a briggs engine, DONT remove the rivits, go down a little further and remove the 4 3/8 bolts that hold the blower housing on.Turn it upside down, prewinf the pulley in the direction that it turns when the rope is being pulled. When it stops turning because the spring is tight, let it unwind one turn and line up the hole in the pulley with the hole in the metal part where the rope comes in and slip the rope in, tie a not and melt the freyed end. Let the starter pull the rope in by itself.
Nov 15, 2009 | Briggs & Stratton Garden
The cord on my electrolux Epic 6500 has been pulled too far out and will not rewind. How can I access the cord reel to rewind?
There are two keys holding the body together, underneath the bumpers on the side of the vac. With the bag door open these keys when gripped with pliers will slide forward to release the body panels.
Before opening the vac, gently push the cord back inside the housing.
2 possibilities:
If the spool rotates and allows the cord to push in , the body must be disassembled, and the cord winder removed and the spring reloaded. This is tricky work. you will need to wind the entire cord onto the spool, then load 3.5 rotations onto the coil spring for tensioning, then reassemble. It's a bit like working on a land mine of you're new at it. Wear safety glasses.
BUT if the spool is locked from the outside and the cord wont push in or pull out, a fine , long blade screwdriver can be inserted diagonal to the body through the cord slot and with luck you can lift a cog of the spool releasing tension and the rewind will work. try that first , but be gentle . You must release the cord spool allowing a a dog ear catch cog to release inside by gently lifting upwards.
Post back to say how you made out,
Or look for an AERUS Electrolux service shop.
Sep 27, 2009 | Electrolux Epic 6500 Vacuum
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
344 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
