Question about Epiq Pc System BPS 9600 MidTower P4 2.4GHz/533MHz FSB/512KB Cache/256MB/20GB/52xCD/NIC/W2K (DSP Version Only) (BPS9600W2KRECOVERYDISK) PC Desktop
Trying to find value of an epiq BPS CPU - Epiq Pc System BPS 9600 MidTower P4 2.4GHz/533MHz FSB/512KB Cache/256MB/20GB/52xCD/NIC/W2K (DSP Version Only) (BPS9600W2KRECOVERYDISK) PC Desktop
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
You need a expert. Thank you.
Posted on Jun 08, 2010
I need the AT&T internet settings for the motrola w510
For Internet, try these settings:
    • Name: MEdia Net
    • Homepage: http://device.home
    • Service Type 1: WAP
    • Gateway IP: 66.209.11.61
    • Port 1: 9201
    • Domain 1: Blank
    • Service Type 2: WAP
    • Gateway IP 2: 000.000.000.000
    • Port 2: 9201
    • Domain 2: blank
    • DNS 1: 000.000.000.000
    • DNS 2: 000.000.000.000
    • Timeout: 15 minutes.
    • CSD No 1: 14152441012 or 18472549271
    • Username: WAP@CINGULAR.COM (required for CSD use only)
    • Password CINGULAR1 (required for CSD use only)
    • Speed (Bps) 1: 9600
    • Linetype 1: ISDN
    • CSD 2: Blank
    • Username 2: Blank
    • Password 2: Blank
    • Speed (Bps): 9600
    • Line Type 2: ISDN
    • GPRS APN: wap.cingular
    • Username: WAP@CINGULARGPRS.COM
    • Password: CINGULAR1
  1. Click Done.
For MMS, try these settings:
  1. Validate the following parameters:
    • Name: MMS
    • Homepage: http://mmsc.cingular.com
    • Port 1: 9201
    • Domain 1: blank
    • Port 2: 0
    • Domain 2: blank
    • Timeout: 10 Minutes
    • CSD no 1: Blank
    • Username: 1: blank
    • Password 1: blank
    • Line Type 1: ISDN
    • CSD no 2: blank
    • User Name 2: blank
    • Password 2: blank
    • Speed (Bps) 2: 9600
    • Line Type 2: ISDN
    • User Name: WAP@CINGULARGPRS.COM
  2. Validate the following settings:
Oct 24, 2010 | Motorola Mobility W510 Mobile Phone
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Need location of the master cylinder redundant bps
The master cylinder is located under the wiper motor on the driver's side. the bps is screwed into the master cylinder underside.
Aug 09, 2009 | 2000 Ford Windstar
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
2008 toyota corolla auto cpu be used on a manual gearbox
No. You cannot use an auto CPU on a manual transmission. The values are markedly different, and the auto cpu has the additional features that relate to the auto trans. I would not try it, you may damage your wiring harness.
Jun 09, 2009 | 2008 Toyota Corolla
Overclocking a CPU Type Intel Pentium IIIE, 581 MHz
If you have an adjustment for the VCORE voltage in your bios, bring it up by one value, then try overclocking the CPU.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Looking for Epiq drivers for version 458947
Can you provide some information about your system configuration.like which is your Epiq model.
Thanks
Feb 17, 2009 | Epiq Pc System BPS 9600 MidTower P4...
Device Drivers needed for win-98 box
Drivers for Windows 98 are hard to find, I would try Driverzone.com first. http://driverzone.com/
BPCS
Nov 08, 2007 | Computers & Internet
Epiq Pc System BPS 9600 MidTower P4 2.4GHz/533MHz FSB/512KB Cache/256MB/20GB/52xCD/NIC/W2K (DSP Version Only) (BPS9600W2KRECOVERYDISK) PC Desktop Logo
Top Epiq Pc System Computers & Internet Experts
David Payne
David Payne
Are you an Epiq Pc System Computer and Internet Expert? Answer questions, earn points and help others
