Question about Nokia 6270 Cellular Phone
My memory has been locked.. how to remove it - Nokia 6270 Cellular Phone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 87 Answers
You need to contact a mobile service centre. They will unlock your memory card by using Memory card password remover. But you will lose all the datas on the memory card.
Posted on Jun 07, 2010
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
My laptop presario cq41's monitor is not displaying anything, but caps lock key and scroll lock is blinking automatically
remove the adaptor and the battery from the laptop tilt the laptop and remove the memory from the compartment and clean the memory with a clean cloth and insert the memory and press it to lock and restart the laptop by inserting the battery
Jul 30, 2011 | Computers & Internet
Remove the memory card - take your finger nail and slide the tiny lever that says "lock" on the side of the memory card to the "unlock" position. Then reinsert the memory card and it will no longer be locked.
Jul 13, 2011 | SanDisk 1GB microSD Memory Card
My nikon camera says "Memory
Remove memory card from camera and slide lock in memory card (check photo).
Dec 02, 2010 | Nikon View DX (25243)
Blank screen on laptop
Sorry to hear you are having problems. I have had this same issue before with this particular model. The following solution works 90% of the time.Perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection. The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules: Step 1 - Remove the electrical power To remove all power from the computer and prevent accidental damage to the electronic components, do the following:
  1. Turn off the computer by pressing and holding down the Power button for about 30 seconds.
  2. Unplug the AC adaptor from the notebook.
  3. Slide and hold the battery release latch to the unlock position.
  4. Use your finger to lift the battery up and out.
  • Remove the memory module cover on the bottom of the notebook .Loosen the compartment's retention screws and lift up and remove the memory compartment cover. Remove the memory modules from the memory slots To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
    1 - Pull the retention clips away from sides of the memory module
    2 - Gently pull the module out of the memory module slot
  • Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.
    After reseating the memory module, replace the cover over the memory compartment before restarting the computer
    Hope this helps FiYa! If you find this solution helpful, please take a moment to leave us some feedback.
    Thank You!
    May 12, 2010 | HP Pavilion dv9000z Notebook
    To clear sd memory card password
    i cant to delete files from my memory card
    Mar 20, 2010 | SanDisk 2GB microSD Memory Card
    Locking with security code
    You need 1 mobile phones and a memory card reader.
    1) Do _not_ turn off the mobile phone!
    2) Remove the Memory Card from the locked phone and put it into a
    memory card reader. Create
    the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
    this directory.
    3) Remove the Memory Card and place it into the locked phone.
    The THC-NOKIA-UNLOCK program should start after 120 seconds.
    4) Remove the battery. Remove the MMC. Put the battery back and restart.
    The Phone Lock has been reset to 12345
    Feb 10, 2009 | Nokia 5200 Cellular Phone
    I have forget my security code of nokia N72 my imei no is 359726002105168.please anybody help me
    try these:
    2) Remove the Memory Card (MMC) from the locked phone and put it into a
    this directory.
    The Phone Lock has been reset to "12345".
    Feb 10, 2009 | Nokia N72 Cellular Phone
    I forgot my lock code!!! Pls do someting
    try these:
    this directory.
    Feb 10, 2009 | Nokia 5700 Cellular Phone
    Nokia 6270 Cellular Phone Logo
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
