Question about HP Pavilion a1310n PC Desktop
Unload msi error c:hp mpsrcCDAsetupUnloadIntent computer is slow and usb ports not working and several tries to load internet pages
    Master:
  • 633 Answers
This problem is the symptom of a bad or incomplete uninstallation.
Download or run 'Windows Install Clean Up' utility and check whether any of the programs u recently uninstalled are still there.
Posted on Jun 07, 2010
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
How to insert camara card to computer
If you have the original USB cable that came with the camera, there is a rubber flap on the side of the camera. Open that flap and the small end of the USB cable will fit into the plug located there.
Then take the larger end and plug it into a USB port on your computer. Depending on the computer you are using, this can be found on the front of the computer or the back. Sometimes there are also ports on the keyboard or monitor. Any USB port will do.
If you have the HP Image Unload software on your computer, simply turn the camera on. If you get a message asking to 'Select the program to launch' click 'Cancel.'
From this point the HP software will 'unload' your images on to your computer when you click 'Start Unload.'
If you do not have the HP software, you need to change a setting in the camera for it to communicate with the computer.
Before you connect the camera with the computer, turn the camera on. Go to either the playback or capture menu and use the down arrow to select the setup menu (it looks like a wrench icon). Press OK.
Using the arrow keys, go to the 'USB Configuration' option and press OK.
Use the arrow keys and select 'Disk Drive' and press OK
Now connect the camera to your computer and go to 'My Computer'
The camera will appear as if it were a disk drive.
Select the camera and manually copy the image files to your computer.
May 05, 2011 | HP Photosmart 435 Digital Camera
Hp pavilion a610y Describe your hp pavilion a610y usb port Problem: Message tells me to unplug my highspeed device from my slow usb port on my zboard keyboard and plug it into one of 6 unused usb ports in...
It is referring to the USB ports on the back of your computer near where your keyboard plugs in. The front ones must be USB 1.1 which will cause this error.
Apr 01, 2011 | HP Pavilion A610y PC Desktop
I have an HP Photosmart C4795 printer. I am getting an error "cartridge error:. I have tried changing to new original HP ink cartridge and loading and unloading cartridge several times. I can not...
Welcome to FixYa!
Try to reset the printer by doing the following;
1. Turn ON the printer.
2. Disconnect the USB printer cable at the back of your printer while the printer is ON.
3. Remove the cartridge.
4. Wait for the "Insert Cartridges" message to display on the message screen of the printer.
(You can skip this if your printer does not have this feature.)
5. Disconnect the power cord from the back of the printer.
6. Wait for 1 minute.
7. Reconnect the power cord.
8. If the printer does not turn on, use the power button to turn it on.
9. Reinsert the cartridges.
10. If the printer prompts you to print a calibration page or requests for a cartridge alignment, please do so.
11. Reconnect back the USB printer cable and try to print.
I hope that this would be helpful to you, thank you for usng FixYa!
Jas247
Mar 07, 2011 | HP Photosmart D5145 Printer
USB ports not working, slow computer
The error you are getting is the USB port driver. I suggest disconnecting ALL of the items you have connected to ALL of the USB ports and rebooting. If the computer reboots normally, go back and install ONE and ONLY one USB device. Restart your machine. If it boots OK, shut down, remove that device and connect another one, restart again. Do this for EACH of the USB devices until you find one that causes the computer to boot slowly and/or generates the error message. That one is the culprit and needs to be repaired before reattaching to your system.
If, however, after removing all of the USB devices initially and rebooting, you still get the error message, then you have a USB driver problem. You will need to remove the USB driver and reinstall from a known good location (like HP's website) to fix the driver problem.
Jan 07, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Jan 08, 2009 | HP OfficeJet 6310 All-in-One Printer...
USB Ports Stopped Working
Check in MSI.com and see if there is a firmware upgrade for that particular motherboard.
Jul 14, 2008 | MSI RS482M4-ILD Motherboard
Usb trouble
update you device in the internet if didn't your again, try to used another OS. Use Windows XP
Jun 08, 2008 | Gateway 4028GZ Notebook
HP D1420
Create a new administrator user account and reinstall the drivers then print. OR check whether u have set it as the dafault printer.
Mar 06, 2008 | Office Equipment & Supplies
HP Pavilion a1310n PC Desktop Logo
449 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
