Question about LaCie (301015) 120 GB Hard Drive
Lacie External Hard Drive FAILED
My fairly new external hard drive has not worked after the first time I performed a back up on my Mac. It won't let me read/write files! I currently dragged my folders into another external hard drive in case this one is totally unrecoverable, but I'd like to use this one as my main back up.
I ran it through disc utility and it just says the following (and I don't know how to repair it):
Verifying volume “LaCie”
Checking Journaled HFS Plus volume.
Checking Extents Overflow file.
Checking Catalog file.
Invalid sibling link
The volume LaCie needs to be repaired.
Error: Filesystem verify or repair failed.
Please help me figure out how to repair this! I have the worst luck with losing my data and I need this for backing up!!!
    Master:
  • 645 Answers
Just format the drive and u will be able to use it.
Posted on Jun 07, 2010
Won't turn on
If this is an external drive you can try buying a new external enclosure and pull the drive out of the LaCie and putting it in the new enclosure. If it still doesn't work then the drive is bad and needs to be replaced.
Dec 22, 2012 | LaCie (300770) 250 GB Hard Drive
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My mac wont find my lacie external hard drive
do u connect it in the keyboard? if yes then that doesnt work cause it doesnt have enough power to go through the keyboard. if u connect it in the back of mac then it should work
Aug 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Trying to drag all files from itunes into lacie 250 g design by porsche hard drive and it won't let me.
Thank you for asking your question with FixYa Support.
I am not sure what type of computer you have that your LaCie is connected to, but first and foremost, make sure the external hard drive has been properly formatted to work with the operating system your computer has.
For Windows computers: the LaCie should be formatted in either FAT32 or NTFS (recommended- more secure).
How to Format a HD in Windows Vista
For Mac computers: the LaCie should be formatted in Mac OS Extended (Journaled) format.
How to format an external hard drive in Mac OS X
If your LaCie is already formatted, then the best way to import your entire iTunes library from the internal hard drive of your computer into the LaCie, especially if you are unable to drag and drop the library into you LaCie, is to try a simple copy and pasting of the ENTIRE iTunes folder from its home on your computer to the LaCie hard drive.
You can also use the website I like to reference which provides some good alternatives to effectively migrating your iTunes Library from a PC or Mac to your external hard drive:
Here is that support link:
How to Transfer iTunes Library to another Computer
(also included in this article, are external hard drives)
For sake of space, I want you to review this article, because I not only agree with its content, it is exactly what I would explain to you as well in a more condensed, easy to follow fashion.
I hope I have helped guide you well on your question.
Regards,
-Mactechtrainer
Mar 28, 2010 | Computers & Internet
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
"The disk LaCie was not repairable by this computer. It is being made available to you with limited functionality. You must back up your data and reformat the **** as soon as possible. Am using it as
Bob,
I had a similar problem with two LaCie external hard drives.
LaCie doesn't manufacture hard drives, they only purchase drives from other companies, like Seagate, and mount those drives in LaCie external enclosures.
If the drive is nearing the point of total failure, then your Mac is letting you know that point is very close. You had better find a new backup device to use. The Mac will let you access the drive for a while longer, but if you do not act, there will come a point when the Mac will not be able to read the data on the drive and any backups you have there will be lost.
When you get a new external hard drive to use for backup, you may not need to do anything with the current drive that is failing, as long as you do not anticipate that you will need anything from the backups that it contains. You can set up the new device as your primary backup. I would then advise that you perform a total backup on the new device ASAP, so that you are not left without at least one good backup.
Sep 27, 2017 | LaCie (300740) 160 GB Hard Drive
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
LaCie (301015) 120 GB Hard Drive Logo
405 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
