Question about Mitsubishi VS-45607 45" Rear Projection Television
Vs 4561 weak picture
Mitsubishi model vs 4561 rear projection tv, has a very weak picture. the bright and contrast are adjusted to max.
everything else works fine.sometimes the picture gets brighter for a while and then returns back to a very dark screen and i can just see those images that have alot of bright colors in them..Any help on replacement part or adjustments would be very apreciated.
  • rockytridge Aug 11, 2008
    no picture, bright blue screen, than blank. [ great audio ] need help !!!
  • 927 Answers
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Posted on Jul 31, 2008
My Hatachi rptv has a very black picture,adjusting contrast and brightness to max won't help,cannot watch any show .
check with the site www.tvrepairkits.com - i believe this is a known issue that they have a fix for already
Jan 23, 2012 | Hitachi 57F500 57" Rear Projection...
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi TV; Model No. VS-45607
Straight from The Mits website
Intro Year:
2000 Chassis:
VZ8 Height:
48" Width:
38 3/8" Depth:
22 1/4" Features:
The Silver Series includes Mitsubishi's most cost-effective projection televisions, yet they outperform by wide margins many of the more expensive models of other manufacturers. With their superb picture, wide assortment of inputs and features, and highly capable system remote control, the Silver Series sets new standards for the entire industry. These exceptional performance features include the following: DIAMOND VISION Optical System 3D-Y/C Comb Filter: Delivers crisp color separations and smooth picture texture. Dynamic White Balance: Ensures color accuracy at all brightness levels. Three S-video Inputs: One in front and two on the rear panel, allowing quick and easy connection of a high-quality camcorder or video game, while simultaneously providing connections for home theater system components such as a digital satellite system and an S-VHS VCR. Component Video Input: Provides the best possible picture quality from a DVD player. 64-Point Digital Convergence Adjustment: Easy to use and provides precise color alignments. 2-Tuner Multi-PIP with Split Screen. 5-Layer Multibrand Remote Control: Allows the operation of a satellite or cable box, a VCR, a DVD player, and an AV receiver-all from one keypad. Intelligent Room Illumination Sensor (IRISþ): Automatically reduces brightness and contrast for a more pleasant viewing experience in a darkened room. Weight (approx.) - 178 lbs Power consumption - 240W
Feb 19, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-6041- picture brightness not very bright
Hi Dawn,
The TV does have a screen control on each of the picture tubes ( there are 3 ) although I do suggest you have a qualified technician make the necessary adjustments as an improper adjustment can cause damage to the set. Should you deside to make these adjustments yourself, you'll need to remove the back ( or front in some sets) ( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE PREFORMING ANY ADJUSTMENTS INSIDE THE SET ) The screen adjustments are located either on the bottom of each tube or in a group component located where the main High Voltage Wire ( large red wire from the black transformer on the deflection board ) is connected to. Look for a turn pot ( screw type adjustment ) that is marked SCREEN. When you locate it ( whether it be on each tube or in the group component ) turn it up only slightly and not to much, as excessive gain ( turning it up to much ) may cause the TV to shut down. When you have the proper brightness ( when it looks good to you ) close the set up and enjoy the renewed picture. Good luck and I do hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Nov 18, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi 10 yr old rear projection
Well, there is no lamp or simple part you can unplug and plug in. I have seen a couple of those sets with that symptom recently and it is caused by a faulty 9 volt regulator on the small signal board. This is not an easy part to change and the repair should absolutely be handled by a tech experienced in Mitsubishi projection sets.
Aug 09, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
192 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
