Question about Sony BDP-S300 Blu-Ray Disc Player
Model bpd3000 remote works fine until I am ready to start the move from the main menu and then the play button and arrow buttons do not work and I cannot get the movie to play. Anyone any ideas??
    Filmmaker:
    Uploaded 5 video answers.
    Problem Solver:
  • 8 Answers
Try pressing HDMI button on the remote and turn off easy link in the menu. failing that it is possible the remote may have faulty buttons. Its always worth cleaning the remote with a clean brush with alcohol spray/gel.
Posted on Nov 10, 2011
How do I get the remote codes to make dish tv remote working?
Method 2 of 3: Scan for Code
  1. Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
  2. Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
  3. Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
  4. Press the remote's power button. Note: use the generic power button, not the TV power button.
  5. Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
    • Do not press the arrow buttons too quickly, or you might skip over the correct code.
    • The mode button for the device will flash rapidly 8 times when you have scanned all the codes for that device.
  6. Lock in the code. When your device successfully powers off, press the Pound sign (#) to store that code in the remote.
  7. Test the connection. Turn on the device with the power button, then test the other buttons such as Play, Fast Forward, etc. If those work too, you're set. If not, repeat the process again until you find a code that does.
Method 3 of 3: By Menu
  1. Turn on your TV. Make sure it's connected to your Dish Network, then press the MENU button.
    • The menu screen should show on your television screen:
    • Select Settings. Locate and select the Remote Control button.
      • The Remote Manager screen should display on your screen:
      • Select the device you want to learn. From the buttons on the right, select TV, DVD, or AUX.
      • Select the Lookup Code button:
      • Select the sort criteria and device brand. Then click the Next button:
        • Test the device at this point. If the remote works as expected, select the "Yes" button; otherwise, select "No" to try the next code in the list.
        • Repeat this process until a working code is found, or continue by selecting "Enter Model" to find the device code.
      • Enter your model number in the search field. You can enter all, or part of the number.
        • Select the device model number from the list, then select Next. Test the device. If it works, you're good to go! If not, and you've tried all the other methods, your device is not supported with the Dish Network remote.
Sep 09, 2014 | Televison & Video
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
Nokia c3 how to make a signature on messsage
1. Open your Nokia . Go to the main menu. The buttonfor the main menu is at the top right of your phone, just underneath thescreen. 2. Move the "Right" arrow until you reach"Messaging." 3. Move the "Down" arrow until you reach"Message Settings." Press the "Center" button to enter thismenu. 4. Choose "Signature" from this menu andpush the "Center" button again. Move the "Down" arrow untilyou reach "Custom," then push the "Center" button. Thiswill open the Signature menu. 5. Write your text signature in the text box on theSignature menu. When you are done typing, press the center button again andthis signature will show in every text you send.
May 23, 2011 | Cell Phones
Need to change language from german to english on my hp deskjet 3050 printer??
Hi deejaynickos
Try this :
Delete driver/software . Disconnect printer .
Download new english driver/software from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140778&lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&taskId=135
Make sure you ' ve selected the compatible OS and complete software .
Reboot , install downloaded software and connect the printer . Wait untill full operation is successfull .
regards ,
fanaudi .
Feb 28, 2011 | HP LaserJet 3050 All-In-One Printer
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Program dish network remote to work on new sharp tv
With the TV turned on. Press and hold the white TV button at the top of the remote until all four light come on at the top of the remote. then press the power button once now start pressing the the up arrow button slowly until the TV turns off then press the # button the TV button will flash Three time your ready.
May 02, 2009 | One For All URC-3021 Remote Control
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Dec 28, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Sony BDP-S300 Blu-Ray Disc Player Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
