Question about Linksys Wireless-G Broadband Router
Help.... im having problems with my router and somebody said the ports mabe blocked and i need to reboot my router..? i dont know much about computers and i need help as i dont know how to reboot my router...i never initially set up the router so im unsure how it works.. im running 2 xbox 360s and im running my laptop wirelessly....weve never had any problems before..its getting very frustrating please help me....
  • Paula75 Apr 10, 2008
    well im about to try your solution.....im going to unplug everything then plug everything back in if i can remember where they go....lol thanks for your help...i hope this works as i really ant to play my xbox....lmao
    Master:
  • 555 Answers
If your router is a Linksys WRT54G, you can look at an instruction manual for the unit here.
To "reboot" the router, all you need to do is turn it off and turn it back on. Since there is no power switch on the unit, this is just done by unplugging it, waiting a few seconds, and plugging it back in again.
Posted on Apr 10, 2008
  • Matt Jurach
    Matt Jurach Apr 10, 2008
    *If you find the solution helpful, please rate it!*
My x-box tells me to open port to connect, i cant get it to work. bungie net tells me to open port 802.11 n not b or g . i cant make it work,x-box tells me my nat is not open. please help. thanks ...
The Linksys router, like any other router, will block "unsolicited" traffic from the Internet coming "into" the router (for "forwarding" to your computer that is "behind" the router).
So, you need to access the web-server "inside" the router, from a computer that is "behind" the router, and you need to modify the "blocking" of the router's "firewall", to "allow" (instead of "block") traffic from the Internet to a specific port-number.
You'll also need to "forward" that port-number to a specific computer "behind" the router.
Compare to a secretary that receives telephone-calls for several managers in the office.
When somebody calls the office, the secretary may look at the caller-ID, and may choose
to *NOT* pickup the telephone, i.e., to "block" the incoming call. Thus, none of the telephones
on the desks of the managers will ring -- they will not receive any notification that the secretary
has "blocked" the call. Or, the secretary may recognize the caller-ID as being that of the spouse of one of the managers, and may just "forward" that incoming call to the correct manager.
The secretary needs to know which of the telephones is associated with the spouse of the caller, so that the "correct" person responds to the incoming call.
The secretary is doing the 'NAT' ("Network Address Translation") to correctly do the "forwarding".
Similarly, the router needs to be configured to do the 'NAT' correctly.
Jul 13, 2011 | Linksys Computers & Internet
Listen Port of TCP: 2869 (Blocked by Firewall/Router) how do i change nat router settings?im blocked when usin bitcomet software
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
Oct 08, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I dont know how to install my D-link 524 router.i need wireless
http://www.it.hiof.no/datakom/lab/di514_QIG_103.pdf
go for this web site you go the your anwers
May 23, 2009 | D-Link DI 514 Wireless Router (DI-514)
Firewall and NAT router configuration/Router problem????
set a port forwarding on your router.
the port you open on port forwarding is the port you are going to use on your bitcommet
Mar 23, 2009 | Computers & Internet
Listenning port bit comet
BitComet requires you to be able to receive incoming connections. If you're behind a NAT router but don't have port forwarding configured properly, incoming connections will be stopped by your router (won't get to your computer).You need to configure port forwarding, so your router knows that the incoming connections are for BitComet and will be allowed through (= forwarded) to your computer.
There are several versions of your router:
DSL-2640B, DSL-2640Bv2,...
Go here, scroll (almost all the way down) and find your router model.
On the next page, skip the advertisement (upper right corner) and look for BitComet.
Simply follow the instructions on that page - they are precise and correct.
In general: You can use ANY port, but I would prefer a listen port between 49152 and 65534 because they're classed as "Dynamic and/or Private Ports" by IANA, so nothing else should be using them by default and they're not the standard ones blocked by ISP's or trackers, but - as I said - you can enter any other port you wish.
If you have any more questions, just come back and let me know - I'm happy to help.
Good luck & thanks for rating!
Mar 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Error81003004
[Solution # 1] (1) Check your firewall to be sure that this port is not blocked.
(2) Ensure that another program is not using the same port number.
Type netstat in command prompt to see all active ports.
[Solution # 2]
Goto Connection  Prefrences and use a http proxy. It helped!!!
[Solution # 3]
It might do this because it cant recognize the internet. Mine does this from time to time too, but I'm not sure if I get that particular error.
Try a couple things.
1. Totally close down Yahoo! and open it back up. See if that helps.
2. If you have a Wireless connection, shut your computer down and basically reboot the connection. Unplug your modem, then your router. Wait 15-30 seconds, then plug in your modem. Wait for the lights to all become solid, plug the router back in, then turn your computer on.
Sometimes a router will stop recognizing your computer. I've had it happen to me, and the odd part of it was I could still browse the net, but not use my IMs.
3. If nothing else works, uninstall and reinstall Yahoo! IM. It may just be a glitch.
[Solution # 4]
Take a look to this address : http://epayvn.info/2009/01/yahoo-messenger-error-81003004.html
Good luck
Mar 03, 2009 | Yahoo Messenger
Problem with my cdr4170
can i connect cdr 4170 to my tv screen?
Dec 26, 2008 | Clover Corporation CDR-4070 Video Recorder
Port forwarding on utorret
Depending on the model you have, you need to enter "applications & Gaming" chose "Port range" and set it to the same Port as your torrent-program, dont forget to point to the IP address on the computer.
Need more, dont hesitate to ask!
/Teis
Helpfull? dont forget to vote
Nov 23, 2008 | Computers & Internet
DL-524 send mail
Are normal network services available to you:-
1) can you ping a server on the Internet?
2) can you browse the Internet?
3) Is the problem only email, if so do you know which mail server you are trying to access?
You shouldnt need to open up any rules in the firewall for SMTP, unless you are hosting a mail server. When you request mail from behind the firewall, most firewalls allow through all traffic from the inside network to the Internet. therefore, if you can see the Internet this is usually a good indication that theres no internal filtering.
all your mail client does is create a connection to port 25 on the SMTP server. You can replicate this by doing :-
telnet <MAIL SERVER ADDRESS> 25
you should get a banner or something up if you can see it. I dont think its a router problem if all other services are woking ok. If you get a banner from the above command, then its definately not a router problem.
ta,
Nov 13, 2008 | Computers & Internet
My RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Aug 23, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Linksys Wireless-G Broadband Router Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
