Question about Ricoh Aficio FX10 Fax Laser Printer
Smoke ricoh aficio fx16 when start printer smoke came out of fuser unit
  • 81 Answers
Well this is really dangerous...this shows a power problem with the printer...so better let the device cool down and change its location before printing
Posted on Jun 07, 2010
Ricoh AFicio C3260 has fuser not set message
Pull the fuser out and put it back in or order a new fuser unit. Please fill out my form for additional information http://ryanluke.net/?page_id=37
Sep 19, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 1013f is duplicating print under each line. Happens on copying, printing and faxing. Have changed process drum unit twice in the last year, fuser unit and had unit cleaned. Was better for...
What type of environment is this copier in? Standard office, warehouse, etc. If the temperature in the area fluctuates a lot, that could have something to do with your problem. Usually ghosting problems like that originate in the fuser. Try increasing or decreasing the fuser temperature to see if that fixes the issue.
Aug 10, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
Part Number for RICOH Aficio 1022
The fuser part number for a aficio MPC 3000 isB2374053 USA
and B2374054 for EU
Jun 01, 2009 | Ricoh Aficio AP2000 Laser Printer
Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Apr 06, 2009 | Ricoh Office Equipment & Supplies
Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Feb 23, 2009 | Ricoh Aficio AP2000 Laser Printer
Ricoh FX16 open heat error
the Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Jan 26, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Jul 06, 2008 | Ricoh Aficio AP2000 Laser Printer
163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
