Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My Candy Washer Dryer CDB 126 is not drying all of a suddern? But i really need it as i have an apartment and no other means of drying clothes
  • 46 Answers
SOURCE: CNW136 Dryer not working !!
lift the lid with the power off and reset the safety stat. look for a and little red button on the metal heater duct on the top of the machine
Posted on Feb 07, 2008
futureloginn
  • 734 Answers
SOURCE: Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Dec 02, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Posted on Aug 21, 2009
  • 5 Answers
SOURCE: combination washer dryer full laundry center does
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Posted on Aug 30, 2009
SOURCE: my candy cmd 146 washer dryer
yes, 2 of them. front of the aly trunking on top of the drum. just press the little ceramic centers and it will work again, done mine 3 or 4 times now, bit annoying to be honest lol
Posted on Mar 29, 2010
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
My candy cmd 146 washer dryer
Sep 11, 2008 | Candy CN146 Front Load Washer
Candy washer dryer not drying
there is a safety feature which advances the timer to a stop position if it overheats on dry. this is caused by poor air flow.
to cure, take the dryer duct off mand clean of lint. this especially accumulates at the bend where the duct enters the tub.
Sep 05, 2008 | Washing Machines
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
