Question about Compaq 17" Flat Screen CRT Monitor
What is wrong
My monitor is not going on and my meter tells me primary v is good but there is 0 v in secondary
My monitor is ok,but i can't put is back to the originals sittings of vista
Posted on Jun 09, 2010
P0351 code loss of power 2.3L08ford ranger,it warms slow and really need to eliminate1~voltage regulator is where?) & 2~ ground through PCM) 3~knowing limits&threashholds{sensorsIGNcircuit}?Ty 0$
P0351 loss of power ? That's not what this code is about . P0351 - Ignition Coil A Primary/Secondary Circuit ,you have a bad coil and possibly a bad coil driver inside the PCM . Do yourself a favor an take your vehicle to a qualified repair shop !
P0351 - Ignition Coil A Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0350 - Ignition Coil Primary/Secondary Circuit Description: Each ignition primary circuit is continuously monitored. The test fails when the powertrain control module (PCM) does not receive a valid ignition diagnostic monitor (IDM) pulse signal from the ignition module (integrated in the PCM). Possible Causes:
  • Open or short in the ignition START/RUN circuit
  • Open coil driver circuit
  • Coil driver circuit short to ground
  • Damaged coil
  • Coil driver circuit short to VPWR
Diagnostic Aids: Use the 12-volt non-powered test lamp to verify START/RUN voltage at the ignition coil harness connector.
Check the coil driver circuit for open, short to VPWR, or short to ground. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test JE .
Feb 18, 2017 | 2008 Ford Ranger
Dual screen wont work
Kevin,
1) You cannot plug a monitor into the VGA connector, on the back of the desktop computer, AND plug a second monitor into a DVI connector, on the back of a desktop computer.
In otherwords you can only plug ONE monitor into the motherboard.
[ The I/O area on the back of the desktop computer, is the Input/Output area. This rectangular area has connections for Input devices, and Output devices.
Examples such as a Mouse, Keyboard, (INPUT), VGA devices, (VGA monitor - Output), USB devices, audio devices, (Speakers - Output. Microphone is an Input device), and so on.
The I/O area has a rectangular metal shield. (Thin metal plate)
Connecting a device in the I/O area, is connecting it directly to the motherboard.
Example of a VGA connector, and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(There are several variations of DVI connectors.
Scroll down ]
To use dual monitors you need a graphics card also.
Graphics card with a VGA connector, or DVI connector. (Or both)
Monitor with VGA cable, plugs into the I/O area on the back of the desktop computer. (Plugs into the motherboard's graphic chipset)
The second monitor plugs into the graphics card's DVI connector, or VGA connector.
[ Just an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1416091&CatId=3669
On the image of the graphics card on the left;
Go under it to the subheading - + 11 larger images and views.
There are 7 views shown. One is the carton the graphics card comes in. (View 2 from the left)
Going from the left side, count over to the 5th view. Left-click on the 5th view. Shows you the 'business end' of the graphics card.
Starting at the left side it is the HDMI connector, then VGA connector, then DVI connector.
Note*
YES, you can plug a VGA monitor, AND a DVI monitor, into this type of graphics card, and have Dual monitors ]
FIRST:
Computer on, Windows running; Put the Installation disk (CD) in the optical drive's tray. (CD/DVD drive)
Load ALL software.
Drivers, and 'Control Panel'.
Graphics card software loaded, close all windows, go back to your desktop screen. Turn the computer off normally.
Unplug the computer from power. Open the computer case.
FOLLOW Anti-Static Precautions.
(Don't know Anti-Static Precautions? Post back in a Comment)
Physically install the graphics card. Close the computer case.
Plug the VGA cable of the Primary monitor, into the VGA connector in the I/O area, on the back of the desktop computer.
Now plug the DVI cable of the Secondary monitor, into the DVI connector on the graphics card.
(The main monitor you use is the Primary monitor. The second monitor you are going to add, is the Secondary monitor )
Plug the computer into power. Both monitors plugged into power, turn them BOTH on.
Turn the computer on.
When Windows loads you will see a display on the Primary monitor.
Your desktop screen.
Now Right-click on an empty area of your desktop screen.
In the list at the bottom, Left-click on - Properties.
In the Display Properties window that comes up, left-click on the -
Settings tab.
You will see two rectangular icons. 1 and 2.
1 is the Primary monitor. 2 is the Secondary monitor.
Left-click on the Secondary monitor icon.
Go down towards the bottom/middle on the left.
Left-click in the empty square to the left of -
Extend my Windows desktop onto this monitor
Go down to the bottom Right. Left-click on Apply.
Go down to the bottom Left. Left-click on OK.
Your desktop screen will now be on the secondary monitor.
When you open your internet browser, (Yahoo, or Google, or MSN, or Mozilla Firefox, etc), you have to DRAG the screen onto the secondary monitor.
(Let's use Yahoo for an example. Yahoo will be on your Primary monitor.
You need to drag Yahoo onto the Secondary monitor)
Which direction you drag, is up to which direction the two monitors are sitting, on your computer desk.
The way the monitors are sitting in Display Properties; the Primary monitor is on the Left. ( 1 )
The Secondary monitor ( 2 ) is on the Right.
This is the way the two monitors should sit on your computer desk.
(There is a way to switch them around, however)
On your Primary monitor, (Still using Yahoo as an example), go to the RIGHT side. See the blue frame going around the screen?
When you bring the mouse cursor ON the blue frame, it turns into a Double-Sided arrow.
It is difficult at first to keep the cursor as a double-sided arrow.
Move too far to the right, it turns into the usual pointed cursor.
Move too far to the left, and it turns into the usual pointed cursor.
have to keep it on the blue frame.
WHILE the mouse cursor is a Double-Sided arrow, left-click, and hold the left mouse button down. Now drag the screen to the Right.
(Move your mouse to the right)
Keep dragging until the Yahoo browser is on both monitors.
Different size monitors? The display will not be the same size, on both monitors.
[ I use an HP 2009m, 20-inch widescreen monitor, as a Primary monitor, and an RCA EN-V, 26 inch HDTV, as a Secondary monitor.
I have my desktop on the Primary monitor, and FixYa, (Firefox browser), on the Secondary monitor, right now ]
If this is not your problem please state in a Comment.
Also state additional questions in a Comment.
Regards,
joecoolvette
May 10, 2012 | Computers & Internet
How do you tell if the coil packs are bad
With an OHM meter to check the resistance
Contributing Member
mtl_4runner-2548.gif?dateline=1060047767
Join Date: Jul 2003 Location: Montreal, QC Canada Posts: 8,805 im_aim.gif So you got codes P0300, P0304 and P0305
You need to check primary and secondary resistences, not just primary as you did.
Primary = 0.67 - 1.05 ohms (You may have a bad multi meter if all read the same)
Secondary = 9.3k - 16k ohms Contributing Member
Secondary = 9.3k - 16k ohmsSo you got codes P0300, P0304 and P0305
Jun 29, 2010 | 2000 Chevrolet Blazer
My cursor use to move from my primary monitor to my secondary monitor in the direction that my monitors are positioned on my desk. Now i need to move my cursor in the opposite direction to my secondary...
easy enough, go to display properties, where the icons of both monitors are displayed, and drag the monitor on the right to the left of the other monitor, Viola! fixed
May 17, 2010 | Computers & Internet
I have power to the HEI distributor, but nothing down the plug wires. I would like a test to see if the internal(removable) coil is good, maybe a resistance value
Below is a generic proceedure for checking your ignition coil.
Ignition Coil Resistance
  • With the key off and the battery lead to the ignition coil disconnected, use an ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
  • To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
f22-39.gif Ohmmeter connected to primary coil terminals.
  • An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
  • To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
Oct 30, 2009 | Chevrolet Impala Cars & Trucks
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
Aug 24, 2009 | Bose Wave Radio
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
P1370 and p1350 trouble codes
P1370 Ignition Control (IC) Module 4x Reference too many pulses
P1350 Ignition Control System
Ok, these codes are signaling a malfunction within the Ignition control module. it is sending way to many signals to the coil. i recommend testing the coil for damage and irregular resistance. i will explain how to do this below. i would replace the module as well. The control moduel is Located Under hood, center, rear engine area, above valve cover, mounted in base of ignition coil pack
Ignition Coil Test Procedures__
* with the key off and the battery lead to the ignition coil disconnected, use an Ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
* To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
* An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
* To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
# A meter reading below the specified resistance indicates a shorted secondary winding. An infinite meter reading proves that the winding is open.
# In some coils, the secondary winding is connected from the secondary terminal to the coil frame. When the secondary winding is tested in these coils, the ohmmeter must be connected from the secondary coil terminal to the coil frame or to the ground wire terminal extending from the coil frame. Many secondary windings have 8,000 to 20,000 ohms resistance, but the meter readings must be compared to the manufacturer's specifications. The ohmmeter tests do not indicate such defects as defective insulation around the coil windings, which causes high-voltage leaks.
May 17, 2009 | 1997 Cadillac DeVille
2 primary ides 2 secondary ides
Ok.... The Primary IDE Should be configured so that your Primary Hard Drive is Set To Master (the jumper pins must be set to the same, each drive has a guide on top or back, or it's written above or below the jumper pins on the back of the drive.
Primary = Hard Disk 0 (Your Main Hard Drive)...This one is to be set as Master and plugged to the END of the IDE Cable....Another Hard Disk / Drive can be connected as Slave (sometimes Cable Select Will Work depending on the motherboard). Remember The Jumper pins on the Drives!
Secondary= One drive must be set as Master, The other as Slave.
That Should do it.
Go into your bios setup screen, go to the boot configuration and set it up so that your boot order goes as follows:
1. Floppy Disc Drive
or........
1. Optical Drive (cd or dvd)
2. Hard Disc 0 (this will be named whatever your Hard drive model number is)
3. Hard Disc 1 (this is the second hard drive, if you want it to be bootable, it's your choice, if not, then set it up to boot off your secondary optical drive,
Make Sure that under IDE devices menu, everything is detected correctly.
Now Save Settings and Exit.
That should do it
Apr 21, 2009 | Computers & Internet
Lenovo ADD2 DVI-D Riser Card display issue
No, not really you just need to move and/or setup any video for the monitor you want to be displayed. You are doing everything right except assigning which folders or files need to be seen on which monitor. all of this can be done within the properties manager for the video. Depending on your system this can be located just about anywhere in the dialouge box. But, you should be able to drag and drop what files you want to display. I this was helpful because you are on the right track. Also visit the Dell tutorial for more information with streaming video to watch and you will be alright after that. If not contact me here.
Good Luck
Fehdi
Mar 12, 2009 | Computers & Internet
Compaq 17" Flat Screen CRT Monitor Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
