Question about HP Pavilion ze1210 Notebook
I purchased a revfurbished MB for my HP5398H
I purchased a refurbished MB for my HP 5398H Laptop. I cannot get the AMD processor locked back into the socket. Best Buy told me that they thought there should be a bracket of some sort that goes over the AMD processor underneath the heat sink that forces the locking mechanism on the socket to slide over into the locked position but when I removed the pld mother board to replace it I don't remember there being such a bracket. With the processor in place I cannot get the top portion of the socket to slide over into the locked position that is cleary marked as wich way the locked position should be. My PC shuts doen nearly immediatley after you depress the power button and I'm certain it's because the processor is not engaged to the pins. Can you help me? I tried the old mother board and I experience the same issue.
  • HP Master
  • 20,706 Answers
100%^ NORMAL for WRONG actions.
the S5398 slim line Desk top>? that?
F5398? or this? google cant find it so, wrong full part number is missing above.
no photos shown if PC, no tag data.
no name of it , (notebook laptop, desktop,mini desktop
nor if the words COMPAQ are there. hopeless
is see vast 5398s made , LT, COmpaq and more. try posted the REAL NAME>
post the full service tag for 100x better answers, (I promise)
GOING TO GENERIC MODE now..... dig?
ok , fixing and old puter
do not run any processor with the heat sink missing
nor its fan missing or DEAD>,ever.
that's super super bad for it and it will shut down but if not lucky
it burns up in seconds. some processor burn 100watts of wasted heat, ever touch a hot 100w light bulb, BINGO.
you need a mobo class 101, for sure this is like rule one. above.
rule 2, do not run it fan dead.
rule 3, do not hot swap parts, ever. Power off first, and push power switch to drain off power buss stored charges.
rule 3, never pull the mobo first, buy one first. then pull so you can not forget how you took at apart?
rule 4: if rule 3 is not possible use photos, they are free today.
for sure of the lock
Rule 5, maybe some one else took off the original hp parts and hacked in others, there,(seen vast times, and am guilty vast times)
again no photos of yours there.
RTM read the HP.com book on your PC
read the service manual it covers this test on all HPs made.
best docs in the business, no im not from HP, im retired, non hp.
looks like 8+ years old PC 2008 (S5398)
rule 5: there are many different CPU mounts made
not only by CPU model but each maker of MOBO
decides on their own , what heatsink/fan assemble type to use
some screw , some are clamped many ways.
but all are spring loaded, all are. and thermal grease is NOT optional ever. Rule 6
there are more rules. lots. all basic electronics really and some basic thermodynamics too.
I purchased a revfurbished MB for my HP5398H - 87b752ab-b0bf-4300-b8b8-900f8a46aacc.jpg
Posted on Mar 16, 2017
  • Anonymous Mar 16, 2017
    see this service tag
    when asking HP questions
    only this can allow help
    its first first.
    see that real model number here,
    all private data there is xxxxxxxxx out.
    if you post that,help gets 100x better.
  • 415 Answers
SOURCE: Windows XP start-up problem - Hangs
When you reinstall xp you will not have to reformat the drive. Just reinstall the operating system. As long as you are in safe mode back up what you need to then reinstall xp.
Mark
If you need more help let me know.
Posted on May 27, 2009
  • 120 Answers
SOURCE: HP dv6000 laptop will not power up
the motherboard has a defective power mosfet on the bottom of the MB beside on the power connector.
Posted on Jul 27, 2009
FoxSysPCTech
  • 107 Answers
SOURCE: hp dv9205us laptop mother board needs replaced
HP just did a recall on most of their laptops, yours should fall under what they call "extended service enhancement" or something to that effect. I just sent mine in for a problem with the motherboard not charging the battery.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&dlc=en&cc=us&lang=en&product=3439691
My situation was a little unique though, I had an extra battery and charger I could test, plus another computer I could swap the battery out with. If you dont have these resources, you will have to convince them that it is one of the things listed on the link I just gave you and that it is a defect and not from neglegence.
Aside from that, there are a few things you can try just to be sure that it is really a fried motherboard and not just some dumb little problem. Ive been told that removing the battery sometimes solves the problem, I have never had this help me before though, I suppose it is worth a try.
Make sure you are holding the power button down for at least 1 full second before releasing, I dont know why, but simply hitting the button quickly wont turn it on.
Remove each component one by one, for example, remove the hard drive, then try to turn it on, then remove the RAM and see if it gives you an error instead of just simply shutting off.
Make sure your power adapter is working. Two lights should be turning on, one in the front, and the ring around the plug.
Make sure its not a problem with the power jack inside the laptop. Really the only way to do this is to pull it apart and either physically check it or to replace it with a new one, this should be a last restort.
If you need to order a new motherboard, buy from someone on ebay with a huge postitive feed back. You dont want to mess around with unreputable people on ebay when you are spending upwards of $100.
Here is an example of a good seller:
http://cgi.ebay.com/HP-Pavilion-DV9000-DV9500-Intel-motherboard-434659-001_W0QQitemZ250369812650QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a4b3428aa&_trksid=p3286.c0.m14
I dont know exactly what kind of motherboard you have, I looked at the manual
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
and it lists several different motherboards for the particular model you have, make sure you get the right one.
You will also need someone to replace the motherboard, or do it yourself, good luck with that. Sometimes you can find some decent repair people on craigs list, just make sure they give you plenty of ways to contact them and be sure that you will be able to find them if they dont return your call.
You could also try Staples, they will repair your computer for $350 no questions asked.
Some of their Easytech people are trained to do motherboard replacements, this would probably cost you about $250 if they did it, but having someone trained to do it in a store is quite rare. Plus they get paid hourly so that particular person would have to be willing to take the time to do the repair.
I am not sure about geek squad, I have never done business with them beucase of the horrible feedback most people give them. I am not sure if it is desereved or not, I suppose it depends on who works at the each store.
Well anyways, good luck.
Posted on Aug 01, 2009
  • 280 Answers
SOURCE: HP PAVILION DV5000 NOTEBOOK BATTERY LOCK TABS BROKEN OFF
You can take it to any HP service center. They'll replace it free of charge if its under warranty and does not have any physical damage.
Posted on Sep 27, 2009
LaptopExpert
  • 458 Answers
SOURCE: HP Compaq NX9420 Laptop Power supply shorted ou
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Posted on Dec 01, 2009
Contact form
i want the password to be dominic20
Sep 18, 2013 | Acer Extensa Computers & Internet
Amd video driver not recognized
install dvd software "hero dvd power play"
Aug 15, 2012 | HP Refurbished Hewlett Packard dm1-3025dx...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Compaq Presario F700EM Notebook PC downgrade XP
Windows XP is pretty old now and not supported by Microsoft with updates. You may want to consider purchasing Windows 10 to install on your computer and/or purchasing an entirely different laptop.Software Empire The 1 Source For Affordable Software Downloads
You may be able to use the Windows Vista drivers, as it does not appear that HP offers drivers for Windows XP.
Compaq Presario F700 Notebook PC series Software and Drivers
When downloading drivers, its best to only download them from manufacturer websites. For example, you may be able to download drivers separately from each device manufacturer:
NVIDIA Drivers:
http://www.geforce.com/drivers
May 19, 2017 | HP Compaq Presario F500 F700 and G6000...
I want to upgrade from a AMD Sempron processor 2800+ 1.6GHz 192MB to a faster AMD processor with more RAM. I have an Acer 3002LC laptop. Can you advise me what CPU will support this...
My advice to you is to purchase a faster/newer laptop.
A new processor plus labour to install the CPU will cost a substantial amount of money and the performance gain will be marginal. Also RAM bottle neck come into affect as 192mb of RAM is not going to cut it, now-days you need at least 2GB of it. I myself prefer AMD their new AMD Athlon 2 X2 CPUs perform really well.
damnor01
Dec 30, 2010 | AMD Sempron 2800+, 1.6 GHz Processor
Need the specs for HP DV7 Laptop motherboard #486542-001. Most interested in what AMD Turion X2 cpu's this motherboard supports
Microprocessor 2.26 GHz Intel Core 2 Duo Processor P8400
Microprocessor Cache3 MB L2 Cache
Memory 4096 MB
Memory Max8192MB
Hard Drive 320 GB (5400 rpm)
Take care.
Jun 01, 2010 | Computers & Internet
Will a hp compaq 6735s support spore?
This is something simple you can do yourself. In the future, look up your model laptop then the specs on game, use google.
"HP Compaq 6735s spec"
http://www.cdfreaks.com/hardware/product/86792-HP-Compaq-6735s-Notebook-PC.html
Processor Processor family AMD Turion X2 Dual-Core Mobile Processor RM-70 Processor clock speed 2000 MHz
Memory Memory upgrade <8192 MB GB Internal memory 2048 MB
Video Video card features ATI Radeon™ HD 3200 Video modes resolution 1280 x 800 WXGA Disk drive Total storage capacity 160 GB
"Spore spec"
http://www.spore.com/what/specs_spore
  • FOR WINDOWS VISTA
  • * 2.0 GHz P4 processor or equivalent
  • * 768 MB RAM
  • * A 128 MB Video Card, with support for Pixel Shader 2.0
  • * At least 4 GB of hard drive space, with at least 1 GB additional space for creations.
Everything seems good, the only thing is how much HD space you have.
My computer>Roll over your mouse above the C drive and you will see how much is free out of your 160gb space.
Sep 10, 2009 | HP Compaq 6735s Notebook
I have an AMD Athlon FX 2 dual processor and am using Core Temp to monitor the temps of which are posting 44 to 50 while using my computer. Is this normal?
I believe normal temperatures range from 41 to 95. At least from this laptop that is running a dual processor:
http://shopping.msn.com/specs/toshiba-satellite-a215-s5802-15-4-inch-laptop-amd-athlon-64-x-2-dual-core-tk-57-processor-1024-mb/itemid913517877/?itemtext=itemname:toshiba-satellite-a215-s5802-15-4-inch-laptop-amd-athlon-64-x-2-dual-core-tk-57-processor-1024-mb
Also somebody else here had the same type of question:
http://answers.yahoo.com/question/index?qid=20090207210838AA922iE
From my experience as long as its not running over 100 then you'll be fine. If you have any doubts about your computer overheating you can always apply more compound to the heatsink and also buy a bigger one where the fan runs faster to keep things cooler inside of the case and always remember to have the side doors on as well.
Jun 20, 2009 | AMD Athlon 64 X2 4800+, 2.4 GHz...
Enquiry abt HP pavilion laptop price
check the link below , for the currently shipping system at HP.
http://www.shopping.hp.com/webapp/shopping/series_can.do?storeName=computer_store&landing=notebooks&a1=Brand&v1=HP+Pavilion
You can get a great deal on holiday packages.
Shop by phone: 1 (866) 638-2088
If you are planning to buy a the DV6700, ie no longer shipped .. the refurbished price tag should be around 200$ not more than that .
Alternatively you can look at Dell , as they sell refurbished systems at great prices.
www.dell.com
Thanks
proton
Dec 09, 2008 | Computers & Internet
HP Pavilion ze1210 Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
