Question about Electrolux Microwave Ovens
Loc function activated on electorlux microwave
My Magic Chef microwave say LOC when you try to start it
Sounds like the child-proof lockout has been activated. The manual would have instructions on how to release it.
Jul 16, 2017 | Magic Chef Microwave Ovens
Micro chef microwave says Lov but the light is on when open door . Clock works. No flashing light jus say Loc
find no instructions for Micro chef try a search thru Google and see if you find it there .
Jul 02, 2016 | Microwave Ovens
I have a Galaxy 721. microwave. There is a beep that sounds every minute and the microwave is not being used. I am stumpped! How do I stop the beeping?
Sounds like someone activated the timer function. See if you can find the timer function in the menu, then turn it off.
Dec 31, 2014 | Microwave Ovens
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
My mother mistakenly locked her samsung microwave. She can't figure out how to unlock it and she can't tell me what model it is. Can you help?
On a friend's Samsung (she didn't tell me her model number either), you lock the keypad by pressing "0" and then "2". Press the same sequence to unlock the pad. Maybe this will work on her model.
May 31, 2011 | Samsung MW7490 Microwave Oven
What does loc mean on my screen, and how do I fix it
To cancel lock;
Touch and hold the cancel/off pad for 5 seconds and the locked should disappear.
Same to lock.
I can't find anything about the LOC, so maybe the rest of the word is just missing.
Try this and see if it works. You can always post back and ask again
if I am wrong.
Feb 11, 2010 | Magic Chef CMV1000B Microwave Oven
Error message "chiLd"
There is a Child Safety lock-out feature on some microwave ovens. This enables the user to lock the keypad to prevent children from playing with the control panel. The model number you have this question posted under has this feature enabled/disabled by pressing and holding the "CLEAR/OFF" button for 3 seconds. However, the display reads "LOC" when the feature is activated. I suspect your model number is different because of the display indication you are receiving. Review your owner/operator manual for how to disable the child lock feature. If you no longer have the owner's manual, or if you still have questions, please post back with your BRAND NAME and MODEL NUMBER, so that I may be able to provide you with better assistance. I hope this helps you.
Nov 17, 2009 | GE JVM1440 Microwave Oven
Mwk100x7 kleenmaid microwave displays in lcd panel 'LOC'
I did solve the problem myself after leaving the microwave alone for 20 minutes after which it reverted to the normal functions. Many thanks for your interest. Kind regards, Ash
Oct 04, 2009 | Microwave Ovens
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
133 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
