Question about Nintendo GameCube Console
I have a new gamcube model DOL101. Can I convert it with to use the component cables like the DOL001? I have the cables and some junk 001's I can use for parts. Thank You!
  • amandascott1 Jun 07, 2010
    My gamecube model DOL101 Has only the one port for audio and video. Can i convert it so i can use the component cables like the DOL 001 does?
    Genius:
  • 1,040 Answers
Dear Amandascott,
Visit to the given link.....
http://maru-chang.com/hard/dol/english.htm
Posted on Jun 07, 2010
    President:
  • 1,561 Answers
Yes this can be converted, since there are ports on the new gamecube where the cables will go into.
Take care.
  • Sulaimon Jimoh Olayemi Jun 07, 2010
    Type the link below in your web browser and see the information therein for your gamecube, it gives the details and information on the above subject matter as you request.
    http://en.wikipedia.org/wiki/Nintendo_Ga...
    The link will give you all necessary information needed.
    Take care.
How can I connect my JVC Everio GZ-MG155 camcorder (with a dock) to the HDMI tv input? What kind of adaptor(s) would I need?
The Everio GZ-MG155 and the dock supports an special A/V cable with composite ( http://store.jvc.com/product.asp?Model=QAM0120-001 ) or S-video ( http://store.jvc.com/product.asp?Model=YTU94146A ) cables for a TV with an analog tuner (NTSC). These signals are 480i. If you want to connect this analog signal to the HDMI port, you need an analog to digital video converter (and the appropriate cables). Something like this would work: http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011406&p_id=9994&seq=1&format=2 . This model will attempt to upconvert the signal to an HD format (720p minimum). Additional converters are here: http://www.hdtvsupply.com/cotohdco1.html . The A/V to HDMI cables will not work so check out these products carefully.
The manual for the JVC Everio GZ-MG155 is available on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL027855 . The direct link to the Instruction manual is http://resources.jvc.com/Resources/00/00/91/LYT1668-001C.pdf .
I hope this helps. If your TV has the legacy analog ports, you just need the original A/V cable.
Jun 03, 2015 | JVC Video Cameras
My question is where is the cable connection on the ALT3213om model
Not all models have cable inputs, if you don't readily see a cable input, you will have to use the RGB inputs or composite input. You may have to acquire a converter to convert cable to RGB or Component input.
May 15, 2015 | Televison & Video
Power Switch Board
I'm not sure what you need the pin-out for. If the cable is damaged or the unit is suspect, simply replace it. The model number for the board and cable is 413988-001. A quick Google search turned up replacement parts for as low as $25. If you want the component for some other purpose, there are better ways to accomplish this.
Aug 04, 2014 | HP Compaq ProLiant ML350 G5 Server
Needto buy ribbon cable
Which ribbon cable do you need? If you are in the U.S. you can probably get it from pacparts.com or call them at (800)421-5080.
Mar 18, 2014 | JVC Car Audio & Video
I want to connect my computer to sony wega triniton kvxr29m80 from the hdmi or vga port to the tv's component or 3rc ports. is it possible..i have tried the hdmi to component cable and it does not...
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
May 11, 2012 | Sony Televison & Video
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
Gamcube games wont work on wii
Sometimes modded Wii's don't like playing Gamecube games.
Sorry man.
-Captain Jake
Feb 12, 2009 | Nintendo Wii Console
Configuring the componet out ?
u can buy a converter for output to configuring the tv. the converter is to connect the cables output to the player.
Dec 24, 2008 | Onkyo TX-NR801 Receiver
Nintendo GameCube Console Logo
79 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
