Question about Onkyo TX-SR875 Receiver
Display doesn't work Onkyo TX-SR805
The led lights dont work and I checked the Pure Audio mode and its off.Sometimes we loose the picture and need to turn the receiver off and on again to get a picture.
SOURCE: Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Posted on Sep 05, 2007
SOURCE: Onkyo 805 sub hook up problem
Looking at the back of the sr805, there is a second subwoofer output, this one is the preout. 4 rca jacks to the right of the non-preout subwooker. Moved it, and all works now.
Posted on May 15, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
jaiki39@yahoo.com
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
Posted on Jul 28, 2008
tech48
  • 624 Answers
SOURCE: listening modes not working??
I am a little hesitant to tell you what this is because sometimes people give bad ratings to an expert when they do not get the answer they want to hear. I will take a chance here and assume you are a reasonable person and tell you what the most likely cause is. I have been reparing these type of receivers for as long as they have been making them, and every time I see this particular problem it is always something on the digital board. This is the board the the optical and coax inputs go into on the back. They also run all the audio thru this board, and when you only get the audio that you have, a problem is going to be found there. There is some good news and some bad news that goes with this, first the good news. Many times (about half), the digital board only needs to have some of the solder reflowed on a few of the IC's and it will return to normal operation. If this is the problem your repair should only cost from $90 to $150 depending on the rates of the shop. Now the bad news, if the board has a couple of bad compnents on it, it will need to be replaced. The reason that is bad news, is because those boards are very expensive, usually over $250 just for the board, if the board is even available. Many of these receivers you can not get the digital board for them. Most all of audio equipment is component level repair and there are not many technicians who can troubleshoot these boards, they are a very difficult task.
I hope this free information was helpful, and if so a "FixYa!" would be the appropriate rating. You do not need to have your receiver fixed in order to give a good rating, only that you are given the correct information.
Let me know if I can be of any more help to you, good luck with your Onkyo.
Dave
Posted on Nov 10, 2008
  • 899 Answers
SOURCE: where can I buy circuit boards for Onkyo Receiver TX-SR805.
have you checked these out , also you can contact the seller for other parts.
check it out !
http://shop.ebay.com/items/_W0QQ_nkwZonkyoQ20partsQQ_armrsZ1QQ_fromZQQ_mdoZQQ_sopZ12
Posted on Mar 15, 2009
Onkyo TX-SR805 Receiver power-on button not working, only the led red light indicator appears. Tried to reset by holding/press vcr/dvr & standby/on button, no result. Please help me solve this problem
Hello, Sorry, if the receiver does not turn on we can't do any troubleshooting. I suggest having your receiver serviced or traded in. Thank you, Onkyo USA
Feb 26, 2017 | Onkyo Audio Players & Recorders
I have a onkyo tx-sr507 and it works great the only problem is the setup feature for the unit doesn't show up on my tv it only shows up on my receiver can anyone help me figure this out my cousin has...
A simple composite video connection from its Monitor Out to the appropriately-selected input on your TV may resolve that.
Or, from the manual...
"While the Pure Audio listening mode is selected, the video circuitry is turned off and only the HDMI OUT outputs video signals."
Jul 12, 2011 | Onkyo Tx-sr507 A/V Receiver
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
Sep 27, 2010 | Audio Players & Recorders
Tx-ds747 no display light,when powering on only stand by mode and the volume knob has light ,how to fix it.
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
Nov 23, 2009 | Onkyo TX-DS747
ONKYO TX-SR805 Display screen does not light up.
Resetting the unit MAY work, however you will reset everything to factory and have to set it all up again. If resetting does not work, sounds like you will be looking for your local, friendly rrepair shop. Onkyo carries a two year warranty on these units, hopefully yours is still under. If not I would contact ONKYO directly because it seems they have had A LOT of problems with the screen on the 805 and 875 models
Sep 30, 2008 | Audio Players & Recorders
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
Mar 02, 2008 | Onkyo TX-SR800 Receiver
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
188 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
