Question about Plumbing
Goulds model C48A95A06 power to pressure switch no power on other side
  • 8,404 Answers
When you have a pressure switch ... its purpose is to read pressure and to allow the power to pass only when the requisite pressure has been reached.
If you have power on one side and not the other ... the switch is "open". Either there is no pressure or the switch is faulty. You could pput a gage in the place of the switch to rule out lack of pressure. Dont 'jump' the switch to make it work. If it is faulty, replace it. It is there for system protection.
Thank you for your interest in FixYa.com
Posted on Jun 07, 2010
I have a pump at cabin it pumps water but won t build up pressure and shut off got this pump 7 years first problem
Normally there is a pressure TANK, used in conjunction with a Booster pump. Do you have one on this system? That's where the pressure is stored. If no pressure, the bladder is either failing or has failed.
Mar 07, 2015 | Goulds Pumps Goulds 1 Shallow Well Jet...
My 8 Yr old 1hp jet pump model JRD10 cycles on and off when i try to use hose at facuet?
I think the pressure switch is cycling your pump when there is a low demand. If your system has a pressure tank, it is waterlogged (has no air in it). If you shut down you system, drain the tank, and the restart you system, it should work. Most tanks are made to be pressurized to a certain pressure before starting up your system. Some tanks have a 'tire valve' on them for pressurizing with air.
Oct 29, 2014 | Goulds Pumps Goulds gt10 1 1 Phase...
Why dont i have water pressure after my pump cycles off
Make sure your tank is well pressurized and not water logged.Is there a significant difference between your cut in and cut off pressure.Check for leaks -water or air.
Sep 07, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
How to fix double starts from points kicking the breaker
If the breaker is tripping you need an electrician to check wiring, pressure switch shouldn't be a problem. Don't try to work your way around electrical, always remember the unit will last longer if electrical is running properly to unit.
Aug 31, 2014 | Goulds Pumps Goulds RGS2012PA -...
Pump has not pressure and will not restart automatically
It may be the back flow check valve. If that valve is bad water will recirculate and never build pressure. If that is OK power it down then power back up. If it does not start then the controller is probably bad.
Nov 29, 2013 | Goulds Pumps Goulds 1AB2 - AquaBoost II...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
My pump when reaches 40 psi clicks on and off contineously
check for a slow leak like a toilet valve. leaking tap in the garden or it may be the non-return valve in the unit is not sealing off and allowing the pressure to leak back into the pump so causing it to cycle. Mostly it will require a new unit to fix.
Jan 27, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
My goulds pump J15 does not engage
These pumps can be wired to operate on either 115 or 230 volts. This shouldn't be an issue if it was previously working. If a new installation, make sure it isn't be connected for 230 volt operation and supplied with 115 volts - and of course; vice versa. Correct improper wiring before continuing. It is very possible that the motor has catastrophically failed due to incorrect voltage being supplied - hopefully this isn't the case.
Check and replace / reset any open fuses / tripped circuit breakers. and try again.
These pumps are often operated automatically via pressure switch. If the correct power is available to the pump it may be a problem with the pressure switch. There are many different types of pressure switches so it will be difficult to go beyond what I have told you already. You might want to see if you can locate a pressure adjustment screw and try varying it to see if it has been set too low to allow the pump to come on.
If no luck, tell me what the application for the pump is (point well pump, etc.) and what controls the pump (pressure switch, etc.). Provide the make and model of the control device and any visible settings. Do not remove any covers unless the power is first shut off.
I hope this helps & good luck!
Jan 10, 2013 | Goulds Pumps Goulds J15 - Convertible Jet...
Plumbing Logo
582 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
