Question about Qca Spas Majestic Series Aruba Xl Hot Tub
HL displayed on digital control panel Aruba 1060
HL displayed but I don't think its actually at the temperture it says. 108 is displated and can't get pump to run. But will run after turning off power and restarting.
Thanks Jamie.
  • 8,404 Answers
Jamie ...
Please do not sit in a tub that is, or claims to be, above 100 degrees F - unless there is a trained, licensed doctor or therapist watching you. 108 is deadly - don't find out by accident.
I think there is something seriously wrong with your tub - you need a pro to look at it. Your tub should not heat above 100 and it should only heat if the pump is running. If it is heating with the pump not running, it will quickly burn out and possibly cause other, expensive troubles.
Thanks for your interest in FixYa.com
Posted on Jun 07, 2010
Aruba spa 1060 error cdoes
Here is a link to the owner's manual:
Aruba Spa Hot Tub Models 2003 Owner Manual
There are also some helpful videos on youtube - here is one:
Jan 02, 2015 | Pool & Spa
Fisher & Paykel Intuitive Eco washing machine wont go the codes 150, 108 and 103 are showing on the digital display panel. what is wrong with it?
Not sure what model of Intuitive Eco you have? 150 and 103 are not common. 108 is a communication error between the display board (with screen and buttons) and the motor controller (the other main board). Check the plug on the harness from display to motor controller, but most likely will need one of the boards replaced. Have a look at the boards for any sign of corrosion which may give you an indication of which one is playing up.
Aug 12, 2013 | Washing Machines
I was given a warnock hersey hot tub model 1060 aruba with no manual. im looking for info on that tub and where i can get a manual.
After i fill the hot tub it keeps drain the water from the bottom, how i can keep it filled.
Jul 02, 2011 | Pool & Spa
Unlock control panel
Press & Hold the JET Button for 6 seconds (Most/Gecko & Hydro-Quip)
or
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Apr 16, 2011 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
I NEED DRIVER CD OF SAMSUNG PRINTER MODEL NO ML 1060
don't worry. its simple. you can download driver from internet. just go to google and type in search page. it open many link page and open any one which is suitable and download the driver. thnak
Aug 03, 2009 | Brother HL 1060 Laser Printer
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Dec 28, 2008 | Arctic Above Ground Rugged Mesh Winter...
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
294 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
