Question about AT&T High Speed DSL Modem
Power light not on
The light on the 2 wire modum blinks for a second when I plug into the power source and then goes out. I cannot acces the internet. The modum is about 2 or 3 years old. Do I need a new one/
    Sergeant:
  • 356 Answers
Contact your internet provider to send you a new one.
^_^
Posted on Jun 07, 2010
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Mitsub
The model listed has a self check: when you turn it on and green power light comes on and goes out in a few seconds, on the front of the set press and hold both the Menu and Input(input may be labeled Source) at the same time and hold for at least 5 seconds.
Release both buttons and the power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat for a total of 5 times.
If you have unplugged the set you will have to plug it back and turn set on, let it fail and then do the check--removing power clears all errors.
Let me know what code you find.
Dec 16, 2012 | Mitsubishi WS-55859 55" Rear Projection...
Will not turn on
If the green power light comes on for a few seconds at turn on and goes out do the self check this set has(I will be here on and off for a while):
when light goes out on the front of the set press and hold BOTH the menu and input (input can be labeled source on some models) for at least five seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
Let me know what error code if any is found and I will direct you.
Note that if you have removed power from the set that will clear the error code and give you a 1,2 error which of course is no error--you have to plug set up and try again to turn it on and do the self check when it fails.
SD TECH
Dec 10, 2012 | Mitsubishi WS-65819 TV
Tv turns on and back off
Most of these sets have a self check----if Green power light comes on for a few seconds and goes off on the front of the set press and hold both the menu and input (source) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
Let me know if you get a error code and what it is.
Unplugging power from the set clears the error code so if that has been done you will have to try to turn set on, let it fail and then do the self check again.
Dec 02, 2012 | Mitsubishi Televison & Video
The on/off relay does not stay engaged
Based on model number listed here:
If set powers up and green light comes on and goes out a few seconds later:
Press and hold menu and input (source) buttons at same time on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of five times.
If the set has been unplugged you will have to plug it in and turn it on letting it fail (unplugging will clear all errors).
Let me know error code and I will explain--2,2 is most common and most easy one to fix.
Jun 12, 2012 | Mitsubishi WS-65908 TV
Tv truns on then turns off
if model indicated do the self check it has:
On front of set when green light for power goes out press and hold both the menu and input (source) buttons at the same time for at least 5 seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
If set has been unplugged you must plug it back and try to get set to turn on--unplugging clears the errors.
Let me know what error you find and I will tell you what it means.
Apr 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
My power source is gone out where can i get it fix and how much
Do the self check this 2001 model (what is model number?)
When green light comes on and goes off on the front of the set press and hold both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what you find.
SD TECH
Mar 05, 2012 | Mitsubishi Televison & Video
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Loose connection
  1. Update the Firmware on your router.
  2. When you lose internet, look on your modem and make sure that no lights have gone out. (i.e. Cable) If this one goes out, it is your provider.
Jun 03, 2008 | Linksys Wireless-G WRT54G Router
AT&T High Speed DSL Modem Logo
272 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
