Question about HP Pavilion dv6000z Notebook
Internet Connection When I am on the internet it will stop and say the "internet connection was lost" and then it restarts the internet connection. I am using a wirless connection, but the connection appears to be good. Someone thought I had a virus so I then installed Norton Anti Virus software, but it did not find any viruses. I don't know what else the problem can be.
  • casulz Apr 10, 2008
    Thanks eriez. I was having a hard time thinking it was my wireless connection because it says that my wirless is "on" and my connection is excellent.
    Not sure what else would be causing the internet connection to be lost.
    oz - this is extremely helpful! thank you much!
    Sergeant:
  • 209 Answers
Dear casulz
righteo, this is sounding like a either a configuration error either between your node computer (laptop) and the comms device (modem router), so best we sart with ensuring that all links to this are established correctly. This wll prevent your node losing the comms device or vice versa. Once you have established that a link is correct, it may be best to ensure that your connection to-and-fro from the commms device is secure. Do this by assigning a WPA key (dont use WEP as this can be hacked by anyone foolish or determined enough to need an internet connection, wich could also explain why you are being booted).
To deal with the security of your modem/router, if you are using winxp, then click on start>run>type in command.com>then type IPCONFIG.
you will end up with a series of numbers, for example 125.67.89.00
This will be your modem/router ip address
just logon to that using windows Internet explorer and typing the IP address in the address window. NOTE: you have to be connected to the comms device for this to work.
Once you bring up what looks like a webpage but with your comms device manufacturer on it, you just then configure yor selected WPA key and can choose anything you like (just remember what it is please, otherwise you will have to reset your comms device and go through the lot again)
once you have done this, you can even go out and buy WiFI repeaters, or build a cantenna, this will boost the signal to your comms device. if you go to google and type in "how to build a cantenna" it will take you to a site, which strangely enough is called "guide to building a waveguide antenna/ cantenna" NOTE: i dont recommend trying this unless you know what you are doing with electronics.
If after even all of this, you still have a problem, then try downloading the latesat drivers and firmware updates for your computer/ laptop,. This may resolve.
If even this fails, check yo dont have spyware, phishers, worms, trojans or anything that is likely to be knicking your bandwidth.
Should this even not help, tyhen i reckon to give your machine a complete wipe and re-install everything bit by bit to see what affects yor system and how (it takes time and is a pain in the backside i know, but it is advisable to be done)
Afterall of this, you still have an issue, then either your modem/router/ comms device has malfunctioned, or your internal WLAN card/ network adapter has gone waffty. which means you will then need to contact someone like myself, who will either overhaul the unit or replace it (whichever is the easiest for you).
Good luck with this, and i hope that it pays off,
just remember to work on it systematically, start with the software environment (includes viruses, malware, warez and intruders) at your computer, then query the configuration, then query the exchange between your computer and the comms device, then finally moving on to the hardware. NOTE::::WEATHER conditions can adversely affect your wireless signals, as can where you have got your equipment located. try to keep it within 30 metres apart and away from re-inforced walls and doors. Probably also not a good idea to put the comms device in a metal box or similar enclosure (as this will make the equipment work harder and still only knock out a **** signal)
once again, good luck, and hope you suceed
oz
Posted on Apr 10, 2008
  • AUSTIN JAMES- ATKINS
    AUSTIN JAMES- ATKINS Apr 10, 2008
    Dear Casulz
    Firstly i want to thankyou for your vote, and secondly i want to find out how you are getting on with regards to your problem.
    How did it go if you tried my instructions that I gave to you early on today? I do hope it worked, but if not then that is all just as good as we can rule out any of the above as faults and continue to work on your problem.
    I have been thinking more about your problem, and indeed your network adapter may have some influence on the quality and speed of your connection. If you are using Belkin or Netgear equipment then you should ideally keep every piece of your comms devices to the same vendor/ manufacturer as this ensures that quality is not going to be screwed off by rival competition.
    There is a tool that you can use in order to analyse your network and this is freely available, i is titled NETSTUMBLER and you can find it by hitting the search bar in google and, strangely enough typing the word netstumbler. The program works by analysing your traffic connection, and if there is a problem, it will help you identify what has caused it to go wrong, so give it a go. You do have to be somewhat familar with transmission protocols and technologies to be able to use the programme to full capabilities, but even a general begiinner should still be able to comprehend and get the jist of what is going on.
    Well I hope this works for you, and i wish you all the best.
    oz
    P.S.
    do let me know how you get on, and hope to hear from you soon, good luck BW
Hi ,
I hope this would help you. You said you're using a wireless connection,,,,, that is a common problem basically. if you are in your room , closed door or anywhere indoor, make sure you have an opening like your window , try to open it and then observe,,,, I always experience the same as yours, when I am travelling around China, my connection is also wireless from ZTE network, although it only gave me a 280.30 kps but it worth using my laptop around. Try it ... nothing to lose anyway.... Pls. send feedback..., maybe we can alternatives to your problems..
brgrds,
eriez
How do i restore internet connection please
Restore Internet connectivity ' AVG
https://support.avg.com/SupportArticleView?...Restore-Internet-connecti...
To restore lost Internet connectivity please follow these steps: Restart your modem: - Unplug your modem/router from the power supply.
Resetting an Internet Connection (Flush DNS) ' Learning ...
247support.custhelp.com/.../resetting-an-internet-connection-(flush-dns)
Nov 22, 2015 - To correct it, please flush and reset the DNS by following the instructions below. You may also need to restart your modem and/or router ...
Fix Problems With Your Internet Connection - YouTube
? 6:35
https://www.youtube.com/watch?v=JgkX7XOZ71Q
Dec 21, 2015 | Internet Computers & Internet
After putting my PC to "sleep" after "restarting" most of the time it has lost the internet connection,why does it do this and how can I stop it.
Resources are being shut off.In Control Panel, Set Power Option Properties to Home / Office Desk. Then go to the Hibernation tab and uncheck it.
Oct 12, 2012 | Dell Computers & Internet
During the playing of a movie on netflix the connection is lost and I have to close netflix and restart.
This is generally caused by a drop in quality/speed of your Internet connection. If the connection drops long enough, the movie must stop.
Run an Internet connection test or contact your Internet Service Provider and have them test the line for you.
Mar 11, 2011 | Video Game Consoles & Games
Green light on internet and wireless are blinking
If you are still experiencing normal internet connection then this blinking is normal. If you have lost connection to the internet then first thing to try is to unplug your modem and router for a minute and then plug them back in.
From time to time static can build up in the connection and you can lose the connection. Restarting the modem and router will reset that connection.
Feb 28, 2011 | Computers & Internet
The remote device or resource won't accept the connection
Try restarting your router. If that doesn't work than check if you didn't accidentally hit the wireless button on your laptop as many people tend to do this and not realize it.
Apr 09, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Wireless printer stopped printing-wireless router light flashing
Restart your Printer so that it can Look for the Connection again, if you havent done this already.
If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
Jan 14, 2009 | NetGear WGT624 Wireless Router
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
HP Pavilion dv6000z Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
